May want to check your rear view mirrors!
Since we took delivery of our 2017 2300 sunseeker there has been a rattle or squeak while driving that seems to have been coming from where the drivers side power mirror switches are located (ford E450) and if I put my hand on the black plastic pod that houses the mirror switches I could most of the time get it to stop..
Well today while running the wire up the A-pillar for my new scan gauge II (which I love) I decided to pull that black switch pod off the drivers door, only one screw holds it in place, and put some rubber edge molding on it to see if that would help with the squeak and I was surprised to find that out of the 3 bolts the secure the mirror to the door which are also located behind the switch pod only two of the bolts had nuts on them and the they were only hand tight and the middle bolt was missing the nut altogether! The bottom bolt on mine on both the drivers and passengers side had the ground wire for the electric mirrors attached to it and the nuts were so loose the wire on the drivers side had actually fallen off which would explain why the mirrors have always sounded like their motor wasn't getting enough power and after I hooked it back up and scuffed the paint up under the bolt to make a better ground connection the mirror motors now sound and act much better! On'the passenger side the same thing was found... Top bolt was somewhat tight, middle bolt missing the nut and the bottom bolt on that side had a different nut installed on it along with the ground wire and the nut is stripped so this weekend I'm going to have to clean the treads up on it and install the correct nut and tighten it down!
By all means this should be warranty work and I will bring it to their attention when I take it in this winter to get some other items fixed and adjusted but there's no way I could leave them like they were as they might have fallen off on our next trip and now that they are tight they are much more rigid and hopefully the squeak is gone as well, I'll find that out this weekend but just wanted to throw it out there that you guys may want to pull those covers off the inside of the doors and check those nuts, bolts and ground wires! It only takes a few minutes and on mine all that was needed to do the job was a Phillips screw drive for the drives side switch cover and a 11mm wrench or deep well socket!
Take Vacations.. Go as many places as you can!
You can always make money..
But you can't always make memories!
