View Poll Results: Is it normal for AC and Microwave to trip circuit breaker?
Yes, its just how it is.
43 |
57.33% |
No, the dealer is full of it.
32 |
42.67% |
07-21-2015, 12:42 PM
#21
Originally Posted by Tiggerdad
I also was able to use both on my previous rig IF I had full voltage at the campground. Check the pedestal to see how many volts you have. I have been in some places was the voltage was a little low and that created problems for me.
Not to hijack the thread, but this post makes it a good time to mention you (everyone) REALLY need one of these:
Progressive Industries RV Surge and Electrical Protection industry lea
(Or its hardwired brother)
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
07-21-2015, 12:43 PM
#22
Having same problem on my 2014 FR3. Never had that problem on my 2011 Coachman Freelander. Electric water heater might be my difference
07-21-2015, 12:44 PM
#23
Originally Posted by TURBS
Attachment 83611read the input.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "15 nights"
That is the rated input - not necessarily the actual AC draw at any given time.
LLVanB
2013 Coachmen Encounter 36KS, 2020 Chevrolet Equinox toad, Roadmaster Falcon 2, Brake Buddy Vantage Select, Protect-a-Tow, 5 Star Tune, M4 LED lights, BIRD, ATS, Xantrex PROwatt 1000 SW Inverter and many other accessories & mods.
07-21-2015, 12:52 PM
#24
Originally Posted by HSVBamaBob
Good idea but the AC & Microwave run together can still trip the main 30A breakers with the electric protection in place & with proper campground voltage
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
07-21-2015, 12:59 PM
#25
Right "but" there is an AC amp draw regardless @ all times from the converter.
It's always charging the battery.
As in the chart I posted 1-8 amps
TURBS
2011 32bhok Sabre
07-21-2015, 01:00 PM
#26
I also highly recommend the progressive industries ems !
TURBS
2011 32bhok Sabre
07-21-2015, 01:40 PM
#27
Originally Posted by DoctorT68
Hello All!
Working through some painful stuff with picking up my new RV.
On our first trip, we noticed that when we are using the AC and the Microwave a circuit breaker trips. I asked the dealer about this and was told that it was normal and that I couldn't use both of them together.
Is this true? It just doesn't make sense to me.
2016 Sunseeker 3050SF
Thanks all,
Bill
No it is not normal. Couple of things can cause this. Here is a post I just sent in another thread with same problem.
How big is you MW and AC? Taking a gues but at that temp everyone is running their AC. This may be dropping you incoming voltage at the pole. Lower voltage means higher currant draw means POP goes the circuit ! I am guessing you don't have a surge protector. If you did you would know for sure what is happening. I would strongly recommend getting one. There are a lot of threads on here about them, this thread is currant:
decent 30 amp surge protector
Jim
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
07-21-2015, 02:01 PM
#28
If we are on shore power, we usually don't have a problem with running both, but once or twice have popped the breaker.
running on the genny, yeah, we will have to shut off the a/c to run the mic. it will pop everytime.
Jim & Evelyn
-2015 Ford F-350 XLT Dually
-2016 Prime Time Spartan 1242X
-2012 Harley Davidson Street Glide (his)
-2004 Harley Davidson Fatboy (hers)
07-21-2015, 02:05 PM
#29
It's the electric water heater being on. Turn it off of you don't want to trip the breaker while using the A/C and micro.
07-21-2015, 02:52 PM
#30
I can use both the AC and microwave. My fireplace turns off if I use the microwave. Normal! but we work with it.
Jim & Pat
2014 Coachmen Freedom Express 297RLDS LE
2014 RAM 1500 HEMI Quad cab
07-21-2015, 03:09 PM
#31
Thanks for your input. We have a surge protector installed in our fifth. It wasn't cheap. About three hundred dollars. It was well worth the price. If you go to a campground with low , reversed or intermittent surges it takes care of that. We used to have one on the main power line but now it is inside the rv and when you plug into post it takes exactly 2 1/2 minutes to get power in the rv. Helps making replacement of electrical equipment not an issue. I would be without one.
07-21-2015, 03:14 PM
#32
Now that is one for the books! Fireplace doesn't use any electric. Once it's lit. The microwave and the air conditioner doesn't use any gas. That makes no sense at all! I'm going to have think about this for a while.
Jim
George Bernard Shaw
07-21-2015, 03:20 PM
#33
Fireplaces in the Fifth wheels are electric and throw out a lot of heat when needed. Takes as much power as the microwave plus.
07-21-2015, 03:23 PM
#34
They require a 15 amp outlet.
the one I looked @ was between 7.5 and 9 amp draw.
TURBS
2011 32bhok Sabre
07-21-2015, 04:06 PM
#35
TURBS
2011 32bhok Sabre
OK, now I understand. I thought they were gas logs.
Jim
George Bernard Shaw
07-21-2015, 04:19 PM
#36
Just to throw in my two cents. We were getting the new Ultra V ready for this weekend. I had the TT running of the generator to get my 30 amps. We had the air on and my DW was running the vac (10 amp). I was checking the TV and the stereo. It tripped the breaker on the generator, but not in the TT. I turned off the TV and stereo, and we didn't have anymore problems and got our cleaning done. I'm sure the breaker on the gen is not the best in the world, either.
07-21-2015, 04:21 PM
#37
we had this issue with the last 2 campers we had before the one we have now, because they were both using the same circuit, the only way to avoid it was to run one to another circuit. I personally think the AC needs to be on a circuit by itself
07-21-2015, 04:22 PM
#38
A/c is normally on its own circuit.
So is microwave.
Confused?
TURBS
2011 32bhok Sabre
07-21-2015, 04:36 PM
#39
Phat Phrog Stunt Crew
2014 Wildcat 327ck
07-21-2015, 04:52 PM
#40
Learned so much from reading all your posts. Thank you so much everyone. Yes I was also running my water heater on electric....Doh!!!
2016 SUNSEEKER 3050SF
The early bird gets the worm, but the second mouse gets the cheese
