View Poll Results: Is it normal for AC and Microwave to trip circuit breaker?
Yes, its just how it is. 43 57.33%
No, the dealer is full of it. 32 42.67%
Voters: 75. You may not vote on this poll
Old 07-21-2015, 12:42 PM   #21
BamaBob's Avatar
Originally Posted by Tiggerdad View Post
I also was able to use both on my previous rig IF I had full voltage at the campground. Check the pedestal to see how many volts you have. I have been in some places was the voltage was a little low and that created problems for me.
Not to hijack the thread, but this post makes it a good time to mention you (everyone) REALLY need one of these:
Progressive Industries RV Surge and Electrical Protection industry lea
(Or its hardwired brother)
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 07-21-2015, 12:43 PM   #22
Having same problem on my 2014 FR3. Never had that problem on my 2011 Coachman Freelander. Electric water heater might be my difference
MandK is offline   Reply With Quote
Old 07-21-2015, 12:44 PM   #23
LLVanB's Avatar
Originally Posted by TURBS View Post
Attachment 83611read the input.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "15 nights"
That is the rated input - not necessarily the actual AC draw at any given time.
LLVanB
2013 Coachmen Encounter 36KS, 2012 Honda CR-V toad, Roadmaster Falcon 2, Brake Buddy Vantage Select, Protect-a-Tow, 5 Star Tune, M4 LED lights, BIRD, ATS, Xantrex PROwatt 1000 SW Inverter and many other accessories & mods.
LLVanB is offline   Reply With Quote
Old 07-21-2015, 12:52 PM   #24
Oaklevel's Avatar
Good idea but the AC & Microwave run together can still trip the main 30A breakers with the electric protection in place & with proper campground voltage
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 07-21-2015, 12:59 PM   #25
TURBS's Avatar
Right "but" there is an AC amp draw regardless @ all times from the converter.
It's always charging the battery.
As in the chart I posted 1-8 amps
TURBS
2011 32bhok Sabre
Old 07-21-2015, 01:00 PM   #26
TURBS's Avatar
I also highly recommend the progressive industries ems !
TURBS
2011 32bhok Sabre
Old 07-21-2015, 01:40 PM   #27
Originally Posted by DoctorT68 View Post
Hello All!
Working through some painful stuff with picking up my new RV.
On our first trip, we noticed that when we are using the AC and the Microwave a circuit breaker trips. I asked the dealer about this and was told that it was normal and that I couldn't use both of them together.
Is this true? It just doesn't make sense to me.
2016 Sunseeker 3050SF
Thanks all,
Bill
No it is not normal. Couple of things can cause this. Here is a post I just sent in another thread with same problem.
How big is you MW and AC? Taking a gues but at that temp everyone is running their AC. This may be dropping you incoming voltage at the pole. Lower voltage means higher currant draw means POP goes the circuit ! I am guessing you don't have a surge protector. If you did you would know for sure what is happening. I would strongly recommend getting one. There are a lot of threads on here about them, this thread is currant:
decent 30 amp surge protector
Jim
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 07-21-2015, 02:01 PM   #28
RVBikers's Avatar
If we are on shore power, we usually don't have a problem with running both, but once or twice have popped the breaker.
running on the genny, yeah, we will have to shut off the a/c to run the mic. it will pop everytime.
Jim & Evelyn
-2015 Ford F-350 XLT Dually
-2016 Prime Time Spartan 1242X
-2012 Harley Davidson Street Glide (his)
-2004 Harley Davidson Fatboy (hers)
RVBikers is offline   Reply With Quote
Old 07-21-2015, 02:05 PM   #29
It's the electric water heater being on. Turn it off of you don't want to trip the breaker while using the A/C and micro.
ActionJackson is offline   Reply With Quote
Old 07-21-2015, 02:52 PM   #30
I can use both the AC and microwave. My fireplace turns off if I use the microwave. Normal! but we work with it.
Jim & Pat
2014 Coachmen Freedom Express 297RLDS LE
2014 RAM 1500 HEMI Quad cab
jd48 is offline   Reply With Quote
breaker, dealer
