Old 10-10-2007, 10:44 AM   #11
RAC
The person or dealer you bought it from didn't have any records?
RAC is offline   Reply With Quote
Old 10-10-2007, 11:08 AM   #12
Nope
wengerda is offline   Reply With Quote
Old 10-10-2007, 09:56 PM   #13
welshman599's Avatar
Send a message via MSN to welshman599
Well you changed the other fluids and I take it the oil looks good & reasonably clear, so unless you are in a northerly climate and want to shift down to a lighter grade for those winter starts, I'd let it go til next spring.
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 10-19-2007, 06:34 AM   #14
My last final question about winterization. I completed the process, and I am very confident that I did everything that it needs to be done to winterize my camper. Now, I received a flyer from Camping World, and their winterization price is $99.00 plus parts. But if you want your water filter winterize it will cost and additional $10.00. What kind of process they have to do to the water filter. In my case, I removed the water filter cartridge prior to winterize the camper. Do I need to do anything else? After completing the winterization process, my water filter empty clear canister was full of antifreeze. I took that antifreeze and emptied it into the traps. Do I need to do anything else in regards to the water filter/canister. Should I have to leave some antifreeze in that clear empty canister? Thanks.
Old 10-19-2007, 01:10 PM   #15
If it's empty there isn't anything to freeze. Leave it empty.
aintgotnun is offline   Reply With Quote
Old 10-19-2007, 03:29 PM   #16
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
I left mine full...but you had a good idea using it elsewhere...I never even thought of it. Shouldn't matter either way.
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
sunseeker le
