Motorhome wiring question
I plan to add a 12 Volt jack in the bathroom with a 20 Amp fuse to operate a small hair dryer. Am trying to find a good 12 Volt source for the supply. I noticed there are unused fuse slots in the panel in the entry well, including fuses that would be for slides (the 2900 has no slides) and others. What I need is to find where one of these wires goes, splice onto it and run to the desired location, install a fuse, and then The Missus can use the small hair dryer for a touch-up, and all is well in the world. Does anyone have any idea where those wires might go? I looked under the Convenience Center but did not see any unused wires.
Thank you all!
Steve & Debbie Russell
2013 Sunseeker 2900
TelescopeClinic
