Old 07-31-2015, 12:09 PM   #11
BendOrLarry's Avatar
Originally Posted by Boso View Post
Why couldn't you wire the fan to the ceiling light so the fan would come on with your light
No can do. The light switch is on the wrong side of a wall stud. I have the switch moved and will show how I did it hopefully later today. It came out good.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 07-31-2015, 12:47 PM   #12
You could wire it that way, and that is the way ours came from the factory. The wall switch provides power to both the ceiling light and the vent fan. Only problem is that DW can not reach the fan switch to shut it off when she wants. I need a DW with longer legs -
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
DickiedooFlagman is offline   Reply With Quote
Old 07-31-2015, 12:55 PM   #13
Nope in this coach the fan wiring and switch have 2 wooden barriers studs between it and any other switch. The wall would have to be opened up to drill through the studs. I have it moved and will take pictures later today. I came up with a pretty clean solution.
Firestone airbags
Old 07-31-2015, 01:05 PM   #14
I will look for your pics. Thanks.
Old 07-31-2015, 06:03 PM   #15
Switch moved!
Okay this what I did.
First pic is the before with the push button switch .
2nd pic is the result of a few minutes at the table saw and router table.
3rd pic is where I applied the home made channel material.
4th pic is the final install of the switch.
I think this will work out just fine.
Name:	2015-07-30 07.56.08 (640x480).jpg
ID:	84666   Click image for larger version
Name:	2015-07-30 09.47.15 (640x480).jpg
ID:	84667   Click image for larger version
Name:	2015-07-31 11.35.26 (480x640).jpg
ID:	84668   Click image for larger version
Name:	2015-07-31 15.51.14 (480x640).jpg
Firestone airbags
Old 07-31-2015, 08:58 PM   #16
That will work!
Old 08-01-2015, 09:29 AM   #17
VinceU's Avatar
Nice job!
Old 09-02-2015, 08:35 PM   #18
Talking Ceiling Fan Switch
Ha! This bothered me, too. I put an old wooden yardstick in the corner of the john! Non tech solution works fairly well!
3010DS
skreps is offline   Reply With Quote
Old 09-02-2015, 09:06 PM   #19
After a few trips with this mod I have to say I'm pleased with it. I thought about a couple non tech solutions but sitting on the crapper and being able to push a button and clear the air is kinda nice, it's the little things I guess 😉
Firestone airbags
Old 09-02-2015, 09:31 PM   #20
Garrette's Avatar
Nice mod. Looks great.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
fan, roo
