Old 08-18-2013, 09:27 AM   #51
What RV model are you driving? Class "C" ??
Tim
2013 Forester #3051SF
2009 Toyoda Tacoma (toad)
2010 Newmar Dutchstar (Sold)
2011 Fleetwood Bounder (Sold)
trwmodela is offline   Reply With Quote
Old 08-18-2013, 10:43 PM   #52
Sunseeker 3170DS. Class C with the Triton V12. Same engine as our friends Thor Class A.
flynmoose is offline   Reply With Quote
Old 08-19-2013, 04:03 AM   #53
NCIC105's Avatar
I think you are referring to the V-10 engine.
NCIC105 is offline   Reply With Quote
Old 08-19-2013, 07:01 AM   #54
::sheepish grin::
What? I don't have a Merlin or a Formula 1 engine under the hood?
That's what I get for using my phone at the end of a long day of driving to reply to a forum post.
You are of course correct. V10 it is!
Old 08-19-2013, 09:25 AM   #55
Flymouse,
Just curious, did you weight your Class "C" with full water, cargo and family onboard?
Tim
Old 08-19-2013, 06:51 PM   #56
2014 Sunseeker 2650S
Class A get the 3-valve head. Class C get the 2-valve head. Neither get the Variable Camshaft Timing of the truck version 5.4L V-8. The 3-valve has about 60 more HP and if on same platform better MPG. The Ford E450 engine compartment is a little too tight for the 3-valve, however the V-10 has a ton of torque in either version.
Joseph Carozzoni is offline   Reply With Quote
Old 08-19-2013, 08:00 PM   #57
Well - thank you Joe. I stand corrected and will be eating crow with my friends!
AND - trwmodela - thank you for prompting me to hit the scales. Time for a diet for me and the motorhome! We were 500# over GVWR!
Since we are now home - we will be unloading the MH. I will leave the bike rack and TOW hitch on and hit the scales again. I have no idea how we we will get rid of 500# though. Will have to start with not carrying ANY fresh water (makes it hard to flush the potty on the roll.)
But - back to the MPG discussion at hand. No doubt 500# extra is making a small difference but we have done some trips WITHOUT the TOAD and have not really seen much improvement (maybe 0.3-0.5 MPG better at best.)
Averaged 7.8 mpg from Southern Indiana through KY, WV, VA and back to Chapel Hill so pretty consistent pulling the TOAD through the Appalachians.
Bottom line - my experience is you won't consistently see north of 8.5 MPG in a 3170DS running 14.5K (or 15K if you are dumb like me). Hang a TOAD and you won't average over 8.
BTW - I ran all the way through WV,VA, and NC coming east without cruise control. Tried my darndest to keep it out of the 3K+ RPM range and eased up the hills as slow as 45mph on the way home. Got 7.8MPG vs the 7.9mpg on the way west using crusie and letting it settle in at 3-3.5K RPM on the big grades. So I'm not convinced that RPM/Gear makes a huge difference for the same grades and speeds. I do avoid 4K+ RPM as much as possible cuz it scares me to have that much mass rotating that fast just under my feet. I don't think that these engines are blueprinted and balanced and it is plain LOUD!
Old 08-20-2013, 01:39 PM   #58
The problem is over loading the rear axle. I was only 120 lbs over weight but my rear axle was 500 lbs over it's maximum of 9600 lbs. I purchased a water flow meter to know exactly how many gallons I am loading onboard now! Easiest thing is reduce fresh water carried. The other thing is move cargo to your toad when traveling. I can move some weight to the front because front axle was under it's maximum.
Tim
mpg
