Old 09-16-2015, 09:25 PM   #1
My pet peeve
My pet peeve is the latches on the sliding drawers, I think I had to repair or replace all of them on our 2300. And on our first trip in our new 2700DS I had to reinstall the latch on the drawer under the range. There seems to be two problems, improper installation, they are screwed into the edge of the plywood and just get knocked loose. And on the large drawers the latch springs are too light to hold the drawer shut. They can be difficult to install because the screw heads a too large and interfere with the latch body.
2016 Sunseeker 2700DS
2010 Jeep Liberty Toad
tlf65 is offline   Reply With Quote
Old 09-23-2015, 05:23 PM   #2
Hoglou's Avatar
Let me add... the black water spray hook up cannot be used with the sewer bay door open. Really, could not have moved it two feet (in any direction)? I would have paid FR an extra 20 bucks for the 35 cents of pex needed.......
120v power in bay, fixed.
stinkyslinky holder, fixed.
storage under dinnette, fixed.
water facuet in bay, fixed. (to rinse toad with coach water)
Light on interior step, fixed.
Space for a beverage cosie between the cooktop and the refig...... gerrrrrr
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 09-27-2015, 01:53 AM   #3
Mike968's Avatar
Tlf65, you can purchase heavy duty replacement latches with a higher weight rating for your larger drawers from camping world. http://www.campingworld.com/category...t-hardware/631
Mike968 is offline   Reply With Quote
Old 09-28-2015, 07:01 PM   #4
Mike968,
I have already purchased the heavier latches, according to my dealer they come standard on Winnebago.
Old 09-28-2015, 07:12 PM   #5
Sagecoachdriver's Avatar
I dumped this morning and went to hook up the hose to the black tank flush. You're right, the lid for the compartment can't be latched. Somebody wasn't thinking when they designed it.
Do you guys use a pressure regulator dedicated just for that hose with another back flow preventer? That's how I have mine set up. Overkill? We have 120psi at home and I don't want to blow out the line or the flusher head.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 2 trips 7 nights
Sagecoachdriver is offline   Reply With Quote
Old 09-28-2015, 07:36 PM   #6
Iwannacamp's Avatar
120 PSI. dear lord you need a regulator or a new gauge. 60 is a lot. Most water municipalities provide a regulator at the water source if it is that much.
2017 Puma 297RLSS
Old 09-28-2015, 07:57 PM   #7
We are at the north end of Los Angeles a mile from the pumping plant. PSI ranges from 90-120psi. Had a few house water pressure regulators blow. The house pressure reduced is 65psi but the sprinklers and where I have my hookups for the MH is full city pressure. That's why I use the regulator.
Old 09-28-2015, 08:07 PM   #8
WolfWhistle's Avatar
I swapped all the hinges for self closers and installed Phlip-It latches. Factory catches aer removed... are not in the way and the doors aren't going to open and let stuff fall out when moving.
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 09-29-2015, 05:22 PM   #9
Hoglou's Avatar
I built a small "water world" against the back wall of the back storage area (pics are in my album). I just split the incoming water line in half and added a male and female connector inside of the black shower pan. This creation lets me control the pressure via a watts reg, run the water thur a blue filter, feed the ice maker in the bay, and gives me a faucet to power the black flush or wash the toad. Since it is down line from the fresh water check value the added bonus is that I can also use coach tank water for clean up.
I got a spin on valterra anti siphon on the flush hose....weird but it works...
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Old 09-29-2015, 08:56 PM   #10
For the black water and freshwater hook ups, get right angle inlets, paste a white plastic hook from a hardware store on the side of the motorhome above the open door, and get a loop of rope to hold the door up when the hoses are hooked up. It works fine.
budblack is offline   Reply With Quote
