Old 03-30-2015, 08:03 PM   #11
rbetzwieser's Avatar
That sounds great. I thought it had to be outside. Much easier to mount it inside! Thanks.
rbetzwieser is offline   Reply With Quote
Old 03-30-2015, 08:06 PM   #12
My hubby just reminded me we had to move it around a bit before we found the perfect spot, but with him moving the antenna, and me watching the Sirius radio display, it didn't take us long to find the right spot.
Larry, Paula & Bailey the Adorable Red Toy Poodle
aspengirl is offline   Reply With Quote
Old 03-30-2015, 08:17 PM   #13
GM
bclemens's Avatar
Originally Posted by edgewant View Post
bclemens:
Is there a Class A Factory Rep that monitors the Berkshire subforum? I know Randy Houser, is he the man?
No idea. I know some of the sales guys over there. But that's about it.
Old 03-31-2015, 05:15 AM   #14
I originally ran the antenna out the driver door jamb, under the hood, and out to the front edge of the left fender. Painted it white to match. It worked well except when heading or parked due north--then the cabover area interfered with the signal. So, I got an "indoor" kit for an XM radio. The antenna is a little bigger, and adjustable angle, and does not need to be on a metal surface to work properly. Ran the wire up to the overhead bunk and attached it to the bunk with velcro. It can be moved around for better reception if you are parked and moved to the side if you need to use the bunk. Works very well and no holes drilled anywhere.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 03-31-2015, 05:41 AM   #15
grumpy0374's Avatar
If you have a gps intigrated into the dash radio unit that replaced the factory Ford unit, that little "black box" is the antenna for the gps system. You can add an XM system by buying a simple xm unit, about 60 bucks at WalMart, and plug it into the "aux" port in the front of the radio head unit. You than contact XM, and they will walk you through setting it up and activating it..
grumpy
grumpy0374 is offline   Reply With Quote
Old 03-31-2015, 06:16 AM   #16
grumpy0374's Avatar
If your radio looks similar to first pic, than the black box, if it looks like the box in 2nd and 3rd pic is the antenna. 4th pic is of a simple Sirus/XM aftermarket hookup.
Grumpy
ID:	72595   Click image for larger version
ID:	72596   Click image for larger version
ID:	72597   Click image for larger version
Old 03-31-2015, 06:53 PM   #17
Adding the XM unit that plugs into the back of the radio makes a nice install. Out of sight, tunes and displays on the radio display, etc. Only additional wire to run is the antenna.
Old 03-31-2015, 06:57 PM   #18
That's the one I bought. I don't want to look at it. Probably install it in a couple weeks.
