Old 05-23-2014, 07:30 PM   #1
rbetzwieser's Avatar
Mystery part
Can anybody tell me what the screw on screen thingy is?
Sent from my SCH-I545 using Forest River Forums mobile app
rbetzwieser is offline   Reply With Quote
Old 05-23-2014, 07:49 PM   #2
Who Dares, Wins
doc73's Avatar
Makes sure junk does not go through the pump from your tank. It is a water filter of sorts for large debris.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 05-23-2014, 07:52 PM   #3
Forbes's Avatar
In as much as it appears to be on a water line, not sure if hot or cold, in line water filter screen. Not very effective for micro filter but would keep large items from passing. It could be some type of backflow filter. Is it on the cold or hot water?
Forbes is offline   Reply With Quote
Old 05-23-2014, 07:59 PM   #4
Who Dares, Wins
doc73's Avatar
It should be on the inlet line between the tank and pump. Do not forget to drain this when winterizing or you will have a surprise at the end of winter...
2015 ChevyHD D-Max
Old 05-23-2014, 07:59 PM   #5
Yes that is on the input side of the pump to keep larger objects from gumming up the works (plastic pieces or dirt) that can come up out of your water tank.
Shurflo Pump Strainers - Twist-on Type - PPL Motor Homes
Walter & Donna
2011 CC LB RAM 3500 CTD 6.7L DRW
2013 Cedar Creek 38FL
2017 Days Planned: 135
38FLCamper is offline   Reply With Quote
Old 05-23-2014, 08:09 PM   #6
Yup inlet side of pump. Did not drain before winter. Did not have one on my other units. I think it cracked slightly. I have a small drip from it. At least now I know what to order. Thanks everyone!
Old 05-24-2014, 08:14 PM   #7
I agree that the thingy is a filter but I'm confused about the tee in the piping above the filter. Mine doesn't have one as it just goes to the tank. Can't think of what else would be connected to the pump inlet.
ATVer is offline   Reply With Quote
Old 05-24-2014, 08:17 PM   #8
Who Dares, Wins
doc73's Avatar
Winterizing hook up maybe?
Sent from my SAMSUNG-SGH-I747 using Forest River Forums mobile app
2015 ChevyHD D-Max
Old 05-24-2014, 08:32 PM   #9
Brother Les's Avatar
If water is left in the filter bowl it could (would) freeze. IF the bowl is cracked from freezing, You can get a replacement at most RV stores. If it is just dripping and not cracked, it may only need some teflon tape on the threads.
Brother Les
