Old 03-14-2015, 06:53 PM   #1
shernandez's Avatar
Mystery water
On a trip from California to Utah, 3rd day in felt the bedroom carpet to be very cold, but in fact was damp. Took the bed off of the fresh box and pump, and was very wet. I thought it was possibly the pump from when we were using it down the road, but no leak. It is wettest under the pump, connected to city water and used pump and cannot feel any water leaking. Any suggestions. Click image for larger version
Name:	ImageUploadedByForest River Forums1426377167.642314.jpg
Name:   ImageUploadedByForest River Forums1426377184.030013.jpg
07 sunseeker 2940ds.
07 Sunseeker 2940 ds
11 Fusion Hybrid
2 boys, 2 dogs, one wife and one Big Kid
shernandez is offline   Reply With Quote
Old 03-14-2015, 07:30 PM   #2
CS300823's Avatar
Maybe one of the sharkbite fittings is leaking unless you have a cracked water line somewhere !! :-(
CS300823 is offline   Reply With Quote
Old 03-14-2015, 07:35 PM   #3
Ford Idaho's Avatar
Check where the filter bowl connects to the body.
Old 03-14-2015, 09:52 PM   #4
shernandez's Avatar
Checked the filter, it's tight. Realized the water pressure is crazy high, even with the regulator on. I'm hoping maybe it the pressure was causing the water to leak thru the threads?? All I can think of because I have not found any water leaks. Even put food coloring in the water to find leaks and nothing.
11 Fusion Hybrid
Old 03-14-2015, 10:11 PM   #5
Director, FROG
F.R.O.G.'s Avatar
Try turning off the water at the campground faucet, turn off all faucets inside the coach, and turn on the pump. If there's a leak anywhere downstream of the pump, the pump should kick on just as it does when you turn on a faucet. If the pump doesn't come on (turn on a faucet first just so you know it's working), then you can rule out a leak anywhere downstream of the pump and at least narrow the search. Is there room to slide a plate under the pump to see if anything drips from the pump onto the plate?
Bob Byrne
Director, Forest River Owners' Group (FROG)
frog@forestriverinc.com
www.forestriverfrog.com
F.R.O.G. is offline   Reply With Quote
Old 03-14-2015, 10:54 PM   #6
Crockett's Avatar
I see screwdriver clamps (2) on the line between the pump and tank. is that pex line or braided hose? if braided hose, the clamps should be nearer the end of the hose past the barb section of the fitting. if the clamps are on pex line that simply wont work. those are flair-it fittings not sharkbite from what I see and are fairly trouble free.
edit: ahhh, those are threaded sections on those fittings. the clamps are probably positioned properly...
Crockett is offline   Reply With Quote
water
