Old 04-05-2018, 10:46 PM   #1
Need help Running lights not coming on
Just went to get gas before the big trip in the AM and found the running lights not coming on ( all the marker lights above the cab on the sides and in the rear along the top) and ideas? Thanks for your time
kitejunky1 is offline   Reply With Quote
Old 04-06-2018, 05:15 AM   #2
Probably a ground issue. Loose or corrosion at a ground wire and/or ground connection.
2016 F250 Super cab long bed
2018 Rockwood 8327SS
Briyoung is offline   Reply With Quote
Old 04-06-2018, 05:21 AM   #3
Garrette's Avatar
Check your fuses. My running lights along with the tag light went out. If memory serves, fuse 11 under the drivers side dash. Check the owners manual for fuse location.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 04-06-2018, 05:26 AM   #4
Oaklevel's Avatar
Fuse??
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 04-06-2018, 12:08 PM   #5
Did you go thru a lot of rain recently?
Joe Fillman is offline   Reply With Quote
Old 04-06-2018, 12:11 PM   #6
Running lights
Did you go thru heavy rain lately
Old 04-06-2018, 12:24 PM   #7
Kaadk's Avatar
Did you make sure your 7-pin is all the way in? I've sometimes had to give mine just a little extra push if it's being difficult to ensure the lights work. I'd have power to the trailer, but not lights for some reason if it's only 'mostly' in.
Old 04-06-2018, 12:38 PM   #8
2012 Solera
Is your Sunseeker on a Mercedes Sprinter chassis by chance? Lots of posts about Sprinter based Motorhomes having problems with the interface module between the Mercedes electronics and the Motorhome's lights. Try searching "Curt" on the forum. Don't believe this applies to Ford or Chevy based Motorhomes.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 04-06-2018, 12:53 PM   #9
Kaadk's Avatar
Oops, sorry, should have paid attention where this thread was when I clicked it out the 'recents'. Please disregard.
Old 04-06-2018, 01:02 PM   #10
Thanks everybody for the reply it ended up being a fuse.
light
