Old 07-04-2016, 06:55 PM   #1
Need help with damaged awning!
We have a 2013 Sunseeker 3100....
Ok, we're on week 3 of a 3 month trip and someone (possibly me) decided to drive off this morning without bringing the awning in. It hit a tree branch, which seems to have pulled a few of the screws partially out in the middle and at the top of one of the awning brackets attached to the side of the RV.
All of the screws are still there but have been pulled part way out of the body of the RV sidewall. I tried tightening them and it helped a little, but it seems as if, whatever they were screwed into (possibly wood behind the sidewall?), has been stripped. Any idea what these screw into and/or how to access the area or what to do?
I'll call the local RV place in the morning and see what they say, but we're only in our current city for another 3 days. I'd love to know if it's possibly a DIY situation or if it's something that really has to be done by a professional.
The awning still works......though due to the screws being a little loose, the bracket tilts slightly one direction and someone needs to push a bit on the arm when closing the awning to get it to close properly. My main concern is that because the screws have been pulled out partially, that water might get in if it were to rain. Any thoughts or ideas? Thanks!
kmergen is offline   Reply With Quote
Old 07-04-2016, 07:07 PM   #2
If the screws are in wood I would insert wooden wedges in the holes with good wood glue , replace the screws with new stainless steel screws then seal the screw heads with a good sealent.
JW DUKE is offline   Reply With Quote
Old 07-04-2016, 08:25 PM   #3
Wandering's Avatar
Wedges or plastic anchors might be easiest. Alternatively drill a new hole an inch or so away and reattach.
Good luck! Had a neighbor stop me from doing same thing despite my "preflight checklist".
Forester 2451s
Happy Campin!
Forester 2451s
Wandering is offline   Reply With Quote
Old 07-04-2016, 08:33 PM   #4
Carknocker Family
Ida Ratherbe Camping's Avatar
Larger diameter screws, imo
Nights camped 2015...20
Nights camped 2016...20
Nights camped 2017...24
2017 Ram 2500
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 07-05-2016, 01:02 PM   #5
dmchapman's Avatar
For this type of repair I like structural epoxy. Inject the epoxy into the stripped holes. Once it is set you can drill new pilot holes.
dmchapman is offline   Reply With Quote
Old 07-05-2016, 02:00 PM   #6
Back to RVing again
OH! Thank Goodness! I thought I was the only one who could ever pull out of a campsite with the awning open and not realize it. Alas! I am not alone. Good luck.
Kevin and Bev is offline   Reply With Quote
Old 07-05-2016, 08:02 PM   #7
Nope, you're not the only one. The worst part is that I didn't even enter through the driver's side door (opposite the awning). I walked right under the darn thing, through the main entry door, went and sat down and started the engine.
Old 07-05-2016, 11:37 PM   #8
FricNFrac's Avatar
X2
Shaun & Michelle
2016 Sunseeker 3010DSF
Shaun & Michelle
FricNFrac is offline   Reply With Quote
Old 07-06-2016, 09:49 AM   #9
MilCop4523's Avatar
happens to the best of us... i also forgot to raise the back jacks on the 5th wheel itching to get on the road last weekend.
forgot to disconnect the sewer line one time -
DON'T ask...
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 07-10-2016, 06:55 PM   #10
Hoglou's Avatar
Go with a bigger screw for now. When you get home use a cocktail straw and file with jb weld. day two drill under size pilot hole and replace with like screws. this can all be done with the awning on...
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
awning
