Old 10-16-2012, 07:55 PM   #1
Need help with Heater - SOLVED
I have a 2003 3100 and it is my first rig. I have never tried the Furnace/heater in the unit beforbut want test for an up coming trip. I dont know anything about except the there is a thermostat on the wall. Its a Suburban . How do I turn it on? Do i just push the lever to the Temp I want and it comes on by itself?
Please any feedback would be greatly appriciated
fmf421 is offline   Reply With Quote
Old 10-16-2012, 09:29 PM   #2
It works just like the thermostat in your home, just turn on your propane supply, make sure your house battery disconnect switch is on, and set your thermostat.
tlf65 is offline   Reply With Quote
Old 10-16-2012, 10:41 PM   #3
2Susan's Avatar
Do you have propane in your tank? Is the tank turned on? (can you use the burner on your stove?) Do you have electricity? Then just switch the thermostat to heat and select a temperature.
If the heater has not been used in a while you might want to clean out the burner area. Bugs sometimes like to build nests etc.
2Susan is offline   Reply With Quote
Old 10-17-2012, 06:55 AM   #4
TURBS's Avatar
You may want to try and turn propane tanks off and slowly turn the valves back on .
Turbs
Old 10-17-2012, 07:11 AM   #5
Herk7769's Avatar
Check the fuse in the power center
Check for gas at the range (3 good blue flames)
Set the switch on the thermostat to heat
set the temp
Simple as that.
HAM CALLSIGN - KC3FFW
Old 10-17-2012, 10:18 AM   #6
Thanks for the help I tested it out and it fired right up and worked fine.
Happy Camping
