Old 10-09-2014, 06:54 AM   #1
New 2015 3050s
Hi there everyone my wife and I have finally purchased out first motorhome. We are experienced campers and have worked our way through many trailers to get to this point! I was wondering if there is anything that I need to know, or if there are any particular modifications that are must do's! Thank you for any input!!
snomanx is offline   Reply With Quote
Old 10-09-2014, 09:37 PM   #2
New 3050s
We picked up our new 3050 last week. I have been busy modifying it. Took out the overhead bunk mattress and carpeted the area and removed the dumb storage tray and cabinet next to the mattress. Makes room for our small freezer and a place to install the satellite receiver. Took the bed apart and added a 3' square storage bin next to the bin at the end of the bed and turned the plywood around so hinges could be moved back 3' from slide wall. I installed air cyls. after joining the plywood into one piece. I moved the woofer speaker to the outside wall to allow more room under the couch. I removed the rear TV and door and put shelves in this storage area. I discarded the hanger racks in the closets and put in shelf and wood clothes rod.
Today, I got the Prodigy brake controller hooked up. I received my SmartLight to replace the light over the coach door. I installed a bypass around the 12v water pump so I can open new valve and fill fresh tank when hooked to campground water valve.
Most ever thing is moved in from 5th wheel, problem was how to move from 38' 5th wheel into 30' Sunseeker. Heading out Sun for maiden voyage.
J. V.
J. V. is offline   Reply With Quote
Old 10-10-2014, 04:28 AM   #3
rbetzwieser's Avatar
Pictures of the bed mod would be great to see.
rbetzwieser is offline   Reply With Quote
305, 3050s
