Just brought home a brand new 2370 on the diesel Ford Transit. Really like a lot of things about it, especially how it drives.
I do have several questions though - I wonder if anyone has ideas?
The unique couch/bed layout on the 2370 works well for our situation - but I can't for the life of me figure out how they intended the cushions to work. I assume some thought must have been put into it.
When retracted they mostly work fine, except the cushions fall down all the time.
When extended there isn't a logical place for the cushions. You can try to set them at an angle, but they tend to just fall into the large gap of wiring and ducting. You'd think they'd fit in snugly in some way, but I haven't found it.
There are velcro patches on the back of the cushions, but they are not attached to anything. It is unclear exactly where you'd want to attach them.
The other question is just around repair of some basic quality control issues. The RV seems to have epoxy/glue strewn about all over the place. I suspect it may not be removable, but maybe this is common and there are approaches to fix? Here is a bunch on the ceiling:
Other small repair item - Whoever installed the control panel did a pretty terrible job and tore up the cabinet covering on each of the four corners. I guess I'll mill a slightly larger plate to mount behind it and cover it? Unless there is a way to repair it?
Final question on batteries -
I had read all these models come with lithium batteries but mine came with a standard AGM. Looks like there is room in there for a second one - am I good to go if I just buy another identical battery and wire them in parallel?
Thanks to anyone with ideas for this new Sunseeker owner. I'm very excited about the motorhome but am eager to work through these small issues before we head out.
