Old 08-16-2014, 11:21 AM   #11
2015 Sunseeker 2300
That would be great have not seen that model yet..in fact this is the first 2300 we have seen used...If we ordered one new we would want a sofa and a pantry would that be possible we are working with Three-way campers in Marietta Ga they seem to be good people
Gingsnap is offline   Reply With Quote
Old 08-16-2014, 11:22 AM   #12
GM
bclemens's Avatar
Yes, you should be able to order it that way.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 08-17-2014, 05:11 AM   #13
We love the U-shaped dinette. Pantry would be nice, but we are willing to sacrifice. We store some food above the kitchen sink (basic supply of can goods, etc.) The center section of the dinette has storage under it. Added a couple of plastic crates to organize the space. The rear section of dinette is screwed down but removing the screws opens another storage space. A plastic crate there holds about a case of water bottles. The cabinets above the dinette can also store lighter food items. All in all, we can store enough for a two week trip.
In the cabinets, I use plastic bins with handles (from container store) to organize cabinets and keep things from just rolling around.
One of the advantages of the U-shaped dinette is that you can easily turn the table 90 degrees. This allows sitting in the front or rear facing area with much more space between you and the table. Makes it more like a sofa seating area. Also allows easier reach to cabinets above dinette for shorter people.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 08-17-2014, 04:24 PM   #14
Jdk
On the 2300 where is the air ride suspension valve? Was going to check the psi and couldn't find it.
Jdk is offline   Reply With Quote
Old 08-17-2014, 05:34 PM   #15
There is one on each side in the storage compartment in front of the rear wheels. There is a little plastic cover over it. When removed you will recognize a standard air valve. It doesn't take much air to fill them, so be very careful and use short spurts of air. I set my to 60 psi. If heavily loaded or a strong cross wind, a little more.
Check them each trip, as they tend to leak a little over time.
Old 08-18-2014, 07:56 AM   #16
Jdk
Thanks. I'll go look!
Old 08-27-2014, 08:50 AM   #17
Jdk
Found the air ride valves. Had some initial difficulty checking the stem. Had to put valve exstensions on. Found that there was NO air in the bags. Have since put 50psi in and can't believe how much it improved the handling. Getting ready to leave on Monday for a four week trip to the west coast. One other question. On the wall panel there are two light switches marked living room and kitchen. I think both of them worked but now the kitchen switch won't turn the light off or on like the living room switch will. The light Will go on and off manually from the actual light. Have I switched something off somewhere else?
Old 08-27-2014, 09:45 AM   #18
Jdk
Yes I did leave the light on when I would turn the light switch off and on from the wall panel switch.
Old 08-27-2014, 10:40 AM   #19
GM
bclemens's Avatar
The living room light switch should be on a 3-way, also switched at the entry door. Kitchen is not.
Old 08-29-2014, 06:39 PM   #20
Hoglou's Avatar
Huh? Must be a newer change. I have one wall switch for the living room light on the water / gen panel.....
Hoglou westGA
KM4HQQ 146.640mhz
