Old 08-01-2016, 08:46 AM   #1
new Generator
It is hot in the south. Took a trip through Texas in 2016 Sunseeker 3010ds with Onan generator. I used the ginney most the day and overnight. I was surprised to see that I needed to add oil after. Is this normal? Also how many hours before I should change oil? Can I use synthetic?
izzaboomer is offline   Reply With Quote
Old 08-01-2016, 09:10 AM   #2
All of your Gen questions can be answered in your Gen service manual/operators! Every engine manual says "CHECK Engine OIL BEFORE Operating"! That really means Every Day! Youroo!!
Old 08-01-2016, 10:06 AM   #3
If I would have had the manual I would have used it. Thanks
Old 08-01-2016, 10:30 AM   #4
Georgia Frog Rally 2017
aceinspp's Avatar
New RV and no Gen manual. Be asking my dealer for the manual packet your suppose to get. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
Old 08-01-2016, 10:33 AM   #5
Post model number of your generator. Will post a link to access the manual.
BBQGUY is offline   Reply With Quote
Old 08-01-2016, 10:43 AM   #6
ilmor's Avatar
Do you know that your oil level was full before you started?
I see you don't have a manual. I don't either LOL. Try going to the Onan (I assume you have) website and downloading the manual, it's probably there. You should use whatever oil they recommend, especially while under warranty.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 08-01-2016, 11:40 AM   #7
Recommended changing oil after 25 hours, I beleive the new ONAN oil is a synthetic. I will only use the ONAN oil .
2014 SUNSEEKER 3010DS
TOADS, 2012 FOCUS OR 1998 JEEP WRANGLER,
Kevin & Judy is offline   Reply With Quote
Old 08-02-2016, 08:05 AM   #8
trdutch's Avatar
I inquired on this forum last month about the Gen Oil and for the first time struck out
What I learned from talking to two RV Techs and Two Onan Techs
Change oil often if yours doesn't have oil filter (like mine) 50-100 hours less if conditions are harsh.Your oil change IS your filter.
Use ONAN Onmax.You will never harm it and if you ever have a problem they will back up their oil but not necessarily any other oil.
It's an easy job I've done it Twice and I'm at 100 hours on a 2014
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 08-02-2016, 10:12 AM   #9
Citrus County, Fl.
GL1800Rider's Avatar
It's not unusual for the gen to use some oil. Mine has about 48 hours and is almost down to the add line. Make sure you are level and the cap is screwed all the way in when you check it.
I believe the manual says to change the oil every 75 hours or one year, whichever occurs first. I have not done mine yet since we had to leave on our current trip 2 weeks sooner than expected. You may find with your Sunseeker that you will have to move the exhaust pipe back about an inch or so to get access the the cover and you will need a star bit I think to remove the cover to get to the drain plug. I am sure somebody will correct me on this if I am wrong.
Here is a link to the manual. I tried to upload it but my internet connection at the campground is pretty bad.
http://power.cummins.com/sites/defau.../F-1123-EN.pdf
2016 Forester 3011DS
2015 Toyota Corrola S toad
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 08-02-2016, 11:07 AM   #10
Thanks guys that helps me out.
generator
