Old 05-25-2013, 11:14 PM   #61
GM
bclemens's Avatar
I actually said channel 4 was being used lately. Also that we have started eliminating the switch box on some models. Play the DVD, try different inputs on the TV. Air channel 3 or 4. AV1 and AV2
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 06-02-2013, 09:24 PM   #62
Love My Sunseeker
DXSMac's Avatar
Sorry, I repeated an earlier post, so wiping out this post.
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 06-02-2013, 09:31 PM   #63
Love My Sunseeker
DXSMac's Avatar
Originally Posted by bclemens View Post
If you have the "non raising, but rotating antenna with the little blue lights" that is the new Jack Digital antenna. Directional, but does not crank up. That needs to be powered off as well to watch cable. Booster is built in.
Yeah, that's the one. The "Stealth jet" antenna. No antenna booster button that I can see on the "stealth jet" antenna.
Directions for the "JACK" say to turn antenna until you see maximum blue lights. Well, that didn't work at one site I was at. At maximum blue lights, got NO channels. At two blue lights (out of four), I got five channels. I even played with the "entenuator" button a bit.
I'm still trying to decide if I like the JACK better than the batwing. I think I would rather have the batwing, even if I have to crank it up.
Old 06-02-2013, 09:35 PM   #64
Love My Sunseeker
DXSMac's Avatar
Originally Posted by Wildkats66 View Post
We just got our 2860 last weekend and I have been learning the DVD/TV/speaker setup. The A-B-Both switch on the cabinet end is wired so the A is the front door speakers and the cabin speakers..B is the cabin and the "loft" bed speakers and BOTH is all of them.
I have those A/B/Both and they don't seem to make a difference if I change them. I still get sound in all the speakers. The A/B/Both switch just seems to be an "idiot switch."
Old 06-05-2013, 11:28 PM   #65
Love My Sunseeker
DXSMac's Avatar
Looks like someone forgot to put your switchbox in. I don't like the switchboxes, I would prefer the independent TV's, but I guess can't get the in dash player to work without the switchbox. It's a brown box, with settings for three different TV's.
Originally Posted by kyleozdin View Post
I have a 2013 sunseeker 2450s and for the life of me I cant figure out how to get the dvd in the dash to play through the back tv or the overhead tv. All forum posts on this topic say to turn the tv to channel 3 and switch the video distribution box to the correct setting.....but I cant find this mysterious switch box. I was told its in the cabinet to the right of the top bunk but its not there. Any help is appreciated!
Old 06-06-2013, 11:00 AM   #66
GM
bclemens's Avatar
again, depending on when it was built some units don't get a switch box, not by omission but by design.
The head unit could be wired directly to the overhead TV. In that instance, you would not turn to channel 3 or 4. You would change the input/source on the TV from AIR to one of the others. I'll be at a show in Denver today, maybe I'll check out which input it is specifically. However just cycling through the 4-5 that are on there is pretty easy.
Old 06-15-2013, 08:10 AM   #67
Maybe I should have put this on another thread but does anyone have any info on how to get the sub - woofer to kick in correctly ? I put a DVD in the crappy player and all I get from the sub - woofer is a low frequency hum. The coach is a 2013 3010 DS with the sight and sound package.
Chas69 is offline   Reply With Quote
Old 06-15-2013, 10:22 PM   #68
Garrette's Avatar
You got a sub-woofer. Where is it located? I have looked.
Garrette is offline   Reply With Quote
Old 06-15-2013, 10:30 PM   #69
It's behind the jack knife sofa.
Old 06-17-2013, 08:54 AM   #70
GM
bclemens's Avatar
Sounds like something might not be wired correctly
