Old 03-19-2015, 03:21 PM   #1
Smile Newbe Sunseeker
Hello- We just purchased a 2011 28.5ft Forest River Sun seeker mounted on a Ford E450 chassis. I am having a check of a time figuring a couple of things out, because the few manuals I do have, don't have a lot of info. First, the power mirrors don't work. I suspect a blown fuse, but can't find the fuse panel, and if I did, there is no info on which one it would be. Second, there is no power to any of the interior coach lights. I suppose the coach battery is dead, but can't for the life of find it either. It might have been removed,but can't even find where it's supposed to be.
Can anyone help
Denis
mtdh is offline   Reply With Quote
Old 03-19-2015, 06:22 PM   #2
hockeytownmom's Avatar
The batteries are under the stairs by the door. Welcome!
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 03-19-2015, 07:01 PM   #3
wesslvm's Avatar
There is a battery disconnect rotary switch along side the stairs.
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
Old 03-19-2015, 07:16 PM   #4
I found the batteries and the rotary switch. Both batteries test good. Now, if I could just find the fuse panel for the mirrors.
Thanks you very much.
Old 03-19-2015, 08:03 PM   #5
Garrette's Avatar
Looks to be fuse 13 in the inside fuse panel. I will try to up load the info.
Name:	ImageUploadedByForest River Forums1426812904.782564.jpg
this is the location of the panel
This is a diagram of the panel.
Name:	ImageUploadedByForest River Forums1426813049.363066.jpg
This is the page where the mirrors are called out.
Name:	ImageUploadedByForest River Forums1426813314.535576.jpg
FYI, the complete E450 owners manual can be downloaded from ford.
Garrette is offline   Reply With Quote
Old 03-19-2015, 08:19 PM   #6
your Ford owners manual should be in the glove box. thats were mine was
rekwiat is offline   Reply With Quote
Old 03-19-2015, 08:59 PM   #7
Appreciate,all the help. I think I can figure out now, which actual fuse it is, but where, in the cab, or under the hood, is the actual fuse panel that controls the mirrors, located in a 2011 Forest River Sun seeker, on a Ford E450 chassis located???. The manual says it's supposed to be to the left of the brake petal, but I can't find it. Other sources said it's under the steering wheel, but can't find anything there either. Puzzled!!
Old 03-19-2015, 09:26 PM   #8
How do you get to the batteries? If they are under the stairs do you take apart the stairs?
Sorry for dumb question
2014 SunSeeker 3170DS
Ford F-450
drakethib is offline   Reply With Quote
Old 03-19-2015, 09:35 PM   #9
Garrette's Avatar
Top stair there is plastic knob on each side. Unscrew the knobs and slide the step cover toward you. Hope this helps.
Old 03-19-2015, 09:38 PM   #10
There are two thumb screws- one on each side of the stair well. Take them out, and pull the step out, and the batteries are in the well.
sunseeker
