If you choose to just blow out the water lines, drain the water heater anyway. You can't blow the water out of it. The compressed air will just bubble though the water and go out the hot water outlet. The gas flue is submerged in the water and cold air will circulate through it by convection, cooling the water. It may take a long period of below freezing temperatures, but it could freeze up. It's not that hard to drain. Just be sure the water pressure is off, open a hot and a cold faucet, and remove the drain plug/anode with a 1 1/16" socket, extension and long handle ratchet or pull handle. Get out of the way. If water is hot, watch out. Replace the drain plug / anode using Teflon tape or pipe sealant.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
