03-26-2014, 09:32 AM
#21
Moving the slide out is an interesting idea and may help. However the fridge is not getting gas either so I do not beleive that's the problem
03-26-2014, 09:45 AM
#22
Is your propane detector "on" inside your RV? Some of them control an electric solenoid near your propane tank to shut gas supply if LP detector activates? If you have a solenoid near your tank it should be warm to the touch if working properly. If cool then solenoid is close and gas shut off.
Fonzie
03-26-2014, 10:08 AM
#23
X2 on the propane detector, in my unit if it is in the off position no gas....electrical solenoid is closed. Flip it on and all is good.
2009 Charleston FR
Fort Worth, TX
Jeep Wrangler Toad
03-26-2014, 10:12 AM
#24
I'm not sure about propane detector. I have the electronic gauge for fill level and a carbon monxide detector inside. This is a motorhome. I only remember seeing a wire for the fill sensor.
03-26-2014, 10:13 AM
#25
There will be a propane detector inside your unit.
Fonzie
03-26-2014, 10:21 AM
#26
usually at floor level.
2009 Charleston FR
Fort Worth, TX
Jeep Wrangler Toad
03-26-2014, 10:22 AM
#27
I once had a bad regulator that didn't allow any gas flow.
03-26-2014, 10:42 AM
#28
I am betting on a bad regulator.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
03-26-2014, 02:31 PM
#29
No gas
The propane detector on the Sunseeker is not connected to a shut off solenoid on the tank.
It could be the regulator, but the ones that have been going bad on 1-2 year old Sunseekers (and others) have been outright leaks. Mine went bad when one year old and it was obvious--propane was flowing freely out of it.
The fact that this happened immediately after filling the tank still makes me think it is something in the way the tank was filled (namely, too full).
2012 Forest River Sunseeker 2300 Chevy
03-28-2014, 09:05 AM
#30
Apparently something stuck. I tapped around valve etc. with a rubber mallet. Low and behold I got gas...
03-28-2014, 10:04 AM
#31
I once disassembled the entire hose/valve assembly looking for a blockage. Blowing thru the hose and valves I found one valve that was blocked. Pushed a little spring plunger thing with a screwdriver and it was stuck. Applied more pressure and it started releasing. Worked it back and forth a few times and gas flowed fine when reassembled. Maybe you solved same problem with a rubber hammer. Good job.
Sent from David's RAZR M.
2018 Forester 3011 DS
04-03-2014, 09:58 PM
#32
My 3270 was inspected by my dealer as a courtesy and replaced the regulator. Warrenty item.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
04-17-2014, 07:12 PM
#33
I have exact same model with same problem. Worked last year, topped off tank and put away for winter.
Today I opened gas valve, I heard a click (check valve seating?), but no flow at stove.
To the original poster, did you get it working?
Wes
2014 Sunseeker 3050S
Honda CRV (TOAD)
04-18-2014, 04:18 AM
#34
Yes tapped around tank with a rubber mallet
04-18-2014, 09:59 AM
#35
Probably a bad regulator. Depending on dealer distance, I would order another one and install. Easy enough to do.
04-18-2014, 12:43 PM
#36
Got it working eventually.
Honda CRV (TOAD)
#37
What was the problem?
04-18-2014, 12:48 PM
#38
+1
Enquiring minds want to know, just incase.
04-18-2014, 01:48 PM
#39
Can't say with certainty. I pulled it apart and checked the internal check was free, put it back together and it still didn't work. I left the compartment door open and went about other things, one which was opening up the slide for first time this spring.
Tried it again and it worked! Could have been the regulator liked the open sun, OR could have been the stove supply hose was crimped with the slide closed?
Who knows!
Honda CRV (TOAD)
04-18-2014, 02:10 PM
#40
I had a very similar issue. I was about ready to replace the regulator and tried switching the tanks around (right to left). I think when I unhooked both tanks something "reset" because it started working again. I switched the tanks back and it still worked fine. Maybe I should keep a rubber woman gitter on board just in case or a spare regulator.
2018 Ford F250
2019 Arctic Wolf F295QSL8
