Old 03-26-2014, 09:32 AM   #21
Moving the slide out is an interesting idea and may help. However the fridge is not getting gas either so I do not beleive that's the problem
DrJMB is offline   Reply With Quote
Old 03-26-2014, 09:45 AM   #22
fonzie's Avatar
Is your propane detector "on" inside your RV? Some of them control an electric solenoid near your propane tank to shut gas supply if LP detector activates? If you have a solenoid near your tank it should be warm to the touch if working properly. If cool then solenoid is close and gas shut off.
Fonzie
Old 03-26-2014, 10:08 AM   #23
gmcnitt's Avatar
X2 on the propane detector, in my unit if it is in the off position no gas....electrical solenoid is closed. Flip it on and all is good.
2009 Charleston FR
Fort Worth, TX
Jeep Wrangler Toad
gmcnitt is offline   Reply With Quote
Old 03-26-2014, 10:12 AM   #24
I'm not sure about propane detector. I have the electronic gauge for fill level and a carbon monxide detector inside. This is a motorhome. I only remember seeing a wire for the fill sensor.
Old 03-26-2014, 10:13 AM   #25
fonzie's Avatar
There will be a propane detector inside your unit.
Fonzie
Old 03-26-2014, 10:21 AM   #26
gmcnitt's Avatar
usually at floor level.
2009 Charleston FR
Fort Worth, TX
Jeep Wrangler Toad
Old 03-26-2014, 10:22 AM   #27
I once had a bad regulator that didn't allow any gas flow.
KQ2N is offline   Reply With Quote
Old 03-26-2014, 10:42 AM   #28
another_newfie's Avatar
I am betting on a bad regulator.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 03-26-2014, 02:31 PM   #29
No gas
The propane detector on the Sunseeker is not connected to a shut off solenoid on the tank.
It could be the regulator, but the ones that have been going bad on 1-2 year old Sunseekers (and others) have been outright leaks. Mine went bad when one year old and it was obvious--propane was flowing freely out of it.
The fact that this happened immediately after filling the tank still makes me think it is something in the way the tank was filled (namely, too full).
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 03-28-2014, 09:05 AM   #30
Apparently something stuck. I tapped around valve etc. with a rubber mallet. Low and behold I got gas...
gas
