Old 03-10-2019, 09:55 AM   #1
tvj
No Hot water but the heater runs outside
This problem is solved but I had no hot water in the cabin but the hot water heater ran. It's under the sink there are bypass valves but it's behind a panel which has four screws in it can understand why this didn't get a door on it. Click image for larger version
tvj is offline   Reply With Quote
Old 03-10-2019, 03:51 PM   #2
sgtlm17's Avatar
If you remove the drawer above that panel you can easily get to the bypass valves without taking that panel off.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 03-11-2019, 08:16 AM   #3
Usually Confused Member
emm-dee's Avatar
Originally Posted by tvj View Post
This problem is solved but I had no hot water in the cabin but the hot water heater ran. It's under the sink there are bypass valves but it's behind a panel which has four screws in it can understand why this didn't get a door on it. Attachment 198435
Areas that have wires joining up and plumbing valves usually do not have doors. Thatís to reduce the possibility of people storing stuff that could move around in that area and cause problems.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 03-11-2019, 08:39 AM   #4
cavie's Avatar
Doors, hinges and latches cost $$$. Not needed because you can remove the drawer.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 03-11-2019, 08:43 AM   #5
Just as a side note... it is ALWAYS a good idea to lift the pop-off valve lever on the water heater to verify you have water in the tank BEFORE firing up either the LP side of the water heater or the electric. The electric element will burn out within a very short time with no water in the tank.
Just a quick lift of the pop-off valve lever will verify water in the tank and avoid a costly mistake.
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 03-11-2019, 08:46 AM   #6
cavie's Avatar
So what was the problem?
Old 03-11-2019, 08:49 AM   #7
The bypass valves were not in the correct position.
Old 03-11-2019, 03:27 PM   #8
I have a similar setup for my water heater, but it is difficult for me to reach in to turn the valves. So, what I did was unscrew the panel and then got stick on velcro on the corners when I stick it back on. This way I just need to pull the panel off.
Rita B
2016 Surveyor 201RBD
2006 Jeep Commander 5.7 Hemi
Camping
2017- 27 days
2018- 100 days
RitaB is offline   Reply With Quote
Old 03-12-2019, 11:16 AM   #9
I removed the screws, added a draw pull to the panel, use velcro squares in the corners of the panel to hold it in place. Used a Blend-Fil pencil to fill the screw holes, looks great. Now panel is easily removed for access to plumbing/water heater.
DEC43 is offline   Reply With Quote
Old 03-12-2019, 12:32 PM   #10
RedLdr1's Avatar
Welcome to the forum. That's not a bad idea as the screws tend to strip out after a few rounds of winterizing and de-winterizing...
Wayne and Christine
2019 R-Pod RP-180 10th Anniversary Edition
2018 Ford F-150 SuperCrew Lariat FX4 (4X4) 3.0L Power Stroke Diesel
RedLdr1 is offline   Reply With Quote
heater, hot water, water
