Old 08-08-2018, 05:39 AM   #1
No ice
On my 2014, 3050S with four door fridge the ice maker is not making ice. I can see air in the water lines. I replaced the solenoid thinking that was the problem. It wasn’t. Suggestions?
DrJMB is offline   Reply With Quote
Old 08-08-2018, 07:10 AM   #2
When you took the supply line off the solenoid...did water come out? Is the feed turned on? Some units have a shutoff valve between the PEX and the 1/4 inch water line to the reefer.
Beyond that, the icemaker may not be asking for water and is either turned off or has a problem firing the valve. Does it appear to cycle anyway. On most units you can hear the valve fire and the ice drop.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 08-08-2018, 07:26 AM   #3
Yes water came out when I disconnected the supply line, the clear 1/4” line. Yes the gears turn and acts like it will dump ice but no ice.
Old 08-09-2018, 06:01 AM   #4
I think something is wrong with supply line. I can see air in the line.
Old 08-09-2018, 06:25 AM   #5
Handyman
Check the supply line entering the ice make to make sure it's not frozen.
2016 Salem Cruise Lite 253RLXL
2013 F-150 5.0 Crew Cab
tfmdgm is offline   Reply With Quote
Old 08-09-2018, 06:55 AM   #6
When you say the "supply line" do you mean the line to the valve from your water supply or the line to the icemaker from the valve?
It is generally hard for the line to the icemaker to freeze since it goes to a channel in the cold icemaker section and not to an actual line. You could take it off or put a separate piece of line in the valve and see if water comes out during the normal cycle.
2015 335DS
Old 08-09-2018, 07:22 AM   #7
If there in no water and only air in the lines..."before" the solenoid, I'd say there in an issue in the supply line from the source. As mentioned earlier...valve shut off on supply line ?? or is there no power to solenoid and it's not opening and it's trapped air in the line ?
TheWolfPaq82 is online now   Reply With Quote
Old 08-09-2018, 07:23 AM   #8
Handyman
Where the water line enters the freezer before it dumps into the spout to fill the icemaker. I have experienced this part of the "Supply Line" freeze. This might not be the problem, but break it down. Water enters a shut off valve. Open? Yes. Water continues to solenoid. Replaced, yes. Water continues through the tubing through freezer wall to ice maker. If ice maker is calling for water and not getting it, you have a restriction, blockage, crimped line, etc. What's your thoughts?
Old 08-09-2018, 08:30 AM   #9
Santabobswife's Avatar
Quick question. Did you have ice and now don't.
Santabobswife
Bob, Diane & Snoopy
2018 3050s Sunseeker
Santabobswife is offline   Reply With Quote
Old 08-09-2018, 08:44 AM   #10
all true, but you don't know that the icemaker is calling for water and actually powering the solenoid. You can run it with another short tube to a mason jar and wait and see if there is any water in the jar. The water line to the icemaker itself generally goes to a fitting on the warm side of the freezer. From there the water flows in a plastic trough that is pretty immune to actually forming an ice block. You can look for one right at the fitting or remove the line from the solenoid and see if you can blow through it.
If that line is plugged the supply line will generally blow itself off the back of the reefer since it is only friction fit into the fitting on the outside wall of the freezer. Not your unit, but the concept is the same....
2015 335DS
