Old 11-12-2017, 02:33 PM   #1
No light when arctic pac switch is turned on
I have a 2017 2800qs sunseeker. The red light does not come on when switch is turned on. The temp outside is 50 degrees f. I can not find a fuse marked for artic pac, does anyone know where the fuse is located on this unit?
Tom C 47 is offline   Reply With Quote
Old 11-12-2017, 03:59 PM   #2
TomAR's Avatar
Same problem, and more
Slightly different model (2018 2400R) but...everything lit up during my PDI several weeks ago, but now that the cold weather is here, I tried to turn it on. No good. Circuit breaker had popped. Re-set it, tried switch again and popped the breaker again. Switched breakers with another 15A, same results - popped breaker. Temporarily switched with a 20A - popped breaker again.
Breaker box is located in my stairwell; see attached pic of cover plate. It's the top, right-side breaker - blue with '15A' written on it. A little button had popped out about 3/16th inch. Yours may be different!
Looked at the switch back-side after opening the 'Convenience Center.' Lots of pretty wiring back there. Trying to find a similar colored wire down underneath coach, but those wires are not the same color as attached to the switch.
Planing to call dealer on Monday.
2018 Sunseeker 2400R MBS (w/dinette)
TomAR is offline   Reply With Quote
Old 11-12-2017, 04:10 PM   #3
Fuse panel is in same location. Non of the fuses are marked for artic pac. Switch lite was on two days ago, but now not coming on.
Old 11-12-2017, 04:14 PM   #4
TomAR's Avatar
Have any of the circuit breakers 'popped?'
Old 11-12-2017, 04:35 PM   #5
TomAR's Avatar
More background
Breaker box cover plate states that battery must be above 13.3V. I'd been plugged into my house with a 15A circuit for past days, so I assume battery was fully charged. Fired up the generator, as a 'full power' test. Still popped circuit breaker.
I'm assuming there is a short somewhere. Duh!
All the related under-coach Artic Pack wiring is connected with water-proof connectors; I'm not ready to start breaking those connections yet.
Old 11-13-2017, 02:05 PM   #6
I believe that your most likely problem is a short, as mentioned above. In my experience, this has nearly always been a pinched wire, shorting out to ground, or to the ground wire for the circuit in trouble. All of the Forest River units I have examined use an actual wire for the ground, or negative wire for every circuit, as do at least some other manufacturers. Generally, it is in the form of flat parallel cable, with a color stripe to identify the hot wire. Looks kind of like grossly oversize lamp cord.
Photo Lab is offline   Reply With Quote
Old 11-13-2017, 05:12 PM   #7
DaGrinch's Avatar
Just for giggles and grins, and since the temp was around 28degrees the other morning, I, too, turned on the arctic pac. Light did not come on. And since I was taking it to its winter home under cover, figured I would look at it a little later.
I'll keep this thread in mind when I check things out in a couple of weeks.... I have liberal visitation rights while it is in storage. 😁
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 11-13-2017, 08:10 PM   #8
OscarsMom2's Avatar
We’ve never used ours, but is it possible that the light only comes on when the packs are actually on? If they are controlled by a thermostat, 50 degrees may not be cold enough for them to actually come on.
2017 Wildcat Maxx 26BHS
2016 Rockwood MiniLite 2503S (2015-2016)
2012 Ford F-150 Eco-Boost
OscarsMom2 is offline   Reply With Quote
Old 11-13-2017, 08:38 PM   #9
Mr. Dan's Avatar
My tank heater switch light comes on when we turn on the switch. Our switch is about elbow height to my DW (see... I'm blaming her since she doesn't know how to find this stuff on her phone!). I've found that lighted switch burning bright red when the temperature was 78įF. There's a possibility the bulb has burned out in the OP's switch.
My water heater propane switch has a light bulb in it but it would never light. The selling dealership said lights never burn in those switches. I removed it, found a 3-connector switch --- 1 for pos. power in, one for ground for the heater relay and 1 unused connector (for the light bulb). I added a short ground for this light bulb tab and now all functions of the switch work. OP's bulb ground might have jiggled off a connector and lost the ground. Pull the switch and check.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 74; booked = 12
Old 11-13-2017, 08:54 PM   #10
In reference to the water heater switch on the panel, mine is wired to come on when it is calling for heat on propane, and goes off after ignition is established. I am not certain, but think the arctic switch light merely indicates that power is available to the heaters, which I assume would have thermostats. Tried mine today, and light came on, as per usual...but that probably does not mean much, as it is in my climate controlled shop, being pampered when not in use.
light, switch
