Old 05-17-2015, 09:48 PM   #1
No power to outside electrical outlet.
I have a 2013 3010, we were out this weekend and during a downpour our outside outlet and outlet by door lost power. I checked breaker in bedroom and it's not tripped. Any suggestions?
Sun seeking is offline   Reply With Quote
Old 05-17-2015, 09:55 PM   #2
Was it working before? Ours has an inside switch and it is GFI protected so check both, all I have to offer.
Timtation is offline   Reply With Quote
Old 05-18-2015, 03:43 AM   #3
On our 3100, the GFI receptacle in the bath feeds the outside receptacle. With shore or generator power, reset your GFI receptacle. It also feeds the receptacle at the kitchen sink.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
Old 05-18-2015, 10:30 AM   #4
Yes, they were both working be fore the rain.
Old 05-18-2015, 12:05 PM   #5
jackandjoanne's Avatar
Agree, bathroom gfi, had the same experience
jackandjoanne is offline   Reply With Quote
Old 05-18-2015, 02:30 PM   #6
Thanks everybody. The crazy ways to connect the dots or wires in this case
Old 05-18-2015, 04:35 PM   #7
Moisture in outlet box trips GFI.
As mentioned above, the quick remedy is to push the reset button on your GFI receptacle in your bathroom (or wherever it may be). The same thing happened to me because water got into the outside outlet box during a heavy rain, tripped the GFI - and it probably will trip yours again in the future during wet weather if you don't fix the real problem. The long term solution is to make sure the outlet box is water-tight: Remove the cover (power OFF) and dry out the box, check the foam cover gasket for mis-alignment, etc., and see if there is any other way that rain water or road splash can enter the box. As long as that box lets water in you will have problems with the GFI tripping. To me, it is bad practice to put multiple outlets on a single GFI (as it makes it difficult to figure out which outlet the problem is coming from), but they all seem to do it to save a few bucks.
Alexha is offline   Reply With Quote
Old 05-19-2015, 07:47 AM   #8
7 Year Class A RV'er
Usually they save money by having only one GFI that will control the exterior plug, the bath outlet and the outlet above the sink in the kitchen area. If you want an "early warning system" that the GFI has kicked, try putting some sort of night light, etc. in the outlet above the sink. When it goes out, the GFI has kicked.
2015 Legacy SR340 360RB
Old 06-17-2015, 09:45 AM   #9
Ground fault bathroom.
mc9diver is offline   Reply With Quote
Old 06-17-2015, 09:49 AM   #10
TURBS's Avatar
X2
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
electric, electrical, power
