Old 11-24-2016, 03:15 PM   #1
No power to receptacle on right side of 3050s
I have no power to 4 receptacles on right side
all other ac/dc works fine
any tips???
Garbelly is offline   Reply With Quote
Old 11-24-2016, 03:38 PM   #2
WolfWhistle's Avatar
any tips???
If AC breakers are good in the load center, look for a GFCI and see it it has tripped. If you have 50 amp service maybe you are missing L1 but L2 is good, or vice versa; but if you have this situation, other AC items would not be working besides the receptacles.
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 11-24-2016, 03:38 PM   #3
Indymule's Avatar
I would look for a tripped GFI outlet. When you say right side are you talking about the passenger side of the coach? Look in the bathroom.
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
Fulltimers since May 2018!
2017 Ford F350 Crewcab Dually Diesel
Officially homeless and loving it.
Ham Callsign K9NDY
Indymule is offline   Reply With Quote
Old 11-24-2016, 03:48 PM   #4
Explanation (for your "professional aloofness" ): They typically install a GFCI outlet in the bathroom and then run 3 or 4 others in series off of that one; the bathroom one will provide the GFCI protection for the others; so if that one is tripped, the others won't have power, either.
2011 Traverse LT, 3.6L, FWD
Old 11-24-2016, 03:49 PM   #5
no power to outside GFI or receptacle on passenger side
no power to GFI so it will not reset
Old 11-25-2016, 03:04 PM   #6
Thumbs up
Found the problem with the help of an RV tech
The receptacle in the fridge compartment was fried
Old 11-25-2016, 03:31 PM   #7
Thanks for reporting back but did the tech offer any explanation of what 'fried' it? Seems there is more to this story.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
305, 3050s, power
