11-06-2017, 07:48 PM
No winterized Sunseeker 2017 2300 and temps below 32 degrees
My Sunseeker is not winterized but all tanks currently empty. Temperature next two nights to hit 30 degrees.
Will this damage anything?
11-06-2017, 08:07 PM
Concern would be if traps contain water or in plumbing. And it gets below 32 inside. Run water pump until you are sure pipes are clear of water and pour a bit of antifreeze in all sink and drains. Or keep inside warm...
11-06-2017, 08:10 PM
RGG, so if I keep inside above freezing, should be ok? Great! Thanks
11-06-2017, 09:34 PM
Outside shower is the first thing to freeze. Well.... at least that's what I heard from a friend. [emoji849]
Happy Campin!
Forester 2451s
11-06-2017, 09:35 PM
Oh ok
11-07-2017, 07:19 AM
I would think an overnight dip in temps, unless it was an extreme freeze, would not hurt it so much. I think if it hit below freezing and stayed there for a day or more then it might be a problem. But I am paranoid and have already winterized mine.
2021 Micro Lite 25FKBS
2021 Ford F-250 XLT CCSB 4wd w/ 6.2l and 6 sp. transmission, 3.73 locking axle
11-07-2017, 07:23 AM
Thank you. Mine might have been winterized except I am leaving to go SouthWest next week.
Late for a New Yorker, but needed to tie up loose ends
11-07-2017, 02:40 PM
why don't you just blowout your lines with air. It only takes a few minutes and if really concerned about the tanks put a bit of anti freeze in them to mix with the water. Might slush up on a cold night but I doubt that it will freeze.
Walter & Anne
2013 Forest River Sun Seeker 3100SS
11-07-2017, 03:40 PM
I wouldn't worry unless it was a hard freeze.
11-07-2017, 04:28 PM
swaps
2017 huh? may need to see ya to consider some updates. Swing by the homestead and I'll swap out a few of your new untested components with some tried and true parts for your trip...
Even if you don't come by safe travels anyways.... and start a mod list.
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
11-07-2017, 09:16 PM
You should be ok if 30 is the low. I don't worry about brief dips like that, it will only be below freezing a very short time during the coldest part of the night. It's the hard freezes or prolonged times below 32 that will bite you.
11-07-2017, 09:39 PM
Sunseeker winterizing
Don’t forget the water filter is full of water & is plastic.
11-07-2017, 10:41 PM
If possible, meaning shore power plugged in, turn on the furnace and set the thermostat to say 45. Open all of the cabinet doors. Open all faucets including the outside and drain via the low point drain. Just to be safe.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
11-15-2017, 08:03 AM
From an inexperienced female solo rver , I spend several nights in 27 degree windy cold weather in S.Dakota. I am driving a 2006 Sunseeker. Kept it toasty warm inside and used my water as needed. I had no problems. Was it luck? Probably .
