Old 11-06-2017, 07:48 PM   #1
No winterized Sunseeker 2017 2300 and temps below 32 degrees
My Sunseeker is not winterized but all tanks currently empty. Temperature next two nights to hit 30 degrees.
Will this damage anything?
rollingporch is offline   Reply With Quote
Old 11-06-2017, 08:07 PM   #2
RGG
Concern would be if traps contain water or in plumbing. And it gets below 32 inside. Run water pump until you are sure pipes are clear of water and pour a bit of antifreeze in all sink and drains. Or keep inside warm...
RGG is offline   Reply With Quote
Old 11-06-2017, 08:10 PM   #3
RGG, so if I keep inside above freezing, should be ok? Great! Thanks
Old 11-06-2017, 09:34 PM   #4
Wandering's Avatar
Outside shower is the first thing to freeze. Well.... at least that's what I heard from a friend.
Forester 2451s
Wandering is offline   Reply With Quote
Old 11-06-2017, 09:35 PM   #5
Oh ok
Old 11-07-2017, 07:19 AM   #6
I would think an overnight dip in temps, unless it was an extreme freeze, would not hurt it so much. I think if it hit below freezing and stayed there for a day or more then it might be a problem. But I am paranoid and have already winterized mine.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 11-07-2017, 07:23 AM   #7
Thank you. Mine might have been winterized except I am leaving to go SouthWest next week.
Late for a New Yorker, but needed to tie up loose ends
Old 11-07-2017, 02:40 PM   #8
why don't you just blowout your lines with air. It only takes a few minutes and if really concerned about the tanks put a bit of anti freeze in them to mix with the water. Might slush up on a cold night but I doubt that it will freeze.
Walter & Anne
2013 Forest River Sun Seeker 3100SS
wogden is offline   Reply With Quote
Old 11-07-2017, 03:40 PM   #9
bikendan's Avatar
I wouldn't worry unless it was a hard freeze.
Equalizer WDH
Old 11-07-2017, 04:28 PM   #10
Hoglou's Avatar
swaps
2017 huh? may need to see ya to consider some updates. Swing by the homestead and I'll swap out a few of your new untested components with some tried and true parts for your trip...
Even if you don't come by safe travels anyways.... and start a mod list.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
sunseeker, winter, winterize
