Old 02-13-2018, 11:29 AM   #11
We just picked up our 2017 2400W. It's been too cold here in the Northeast to try the A/C heat pump. But we have run the generator and it is loud and vibrates a lot. Being positioned right underneath the bed will probably make it unusable while sleeping. I was kind of wondering if maybe there were some bolts that were used during transport that need to be released (like when you buy a new washer or dryer). Due to the weather and white stuff on the ground, I haven't investigated it too much. Is this normal for the Onan 3600 W propane generators or is it just poor placement of the unit in the rig? I'd be interested in hearing some input for others as well.
murphytm2001 is offline   Reply With Quote
Old 02-13-2018, 11:53 AM   #12
psgrandpa1's Avatar
We just picked up 2017 SUNSEEKER 2400W MBS...YESTERDAY.
WE GOT CALLS INTO dealer...a/c was so loud...you couldnít even have a conversation. Weíre trying to negotiate a change out to another. Iíve got a pretty good thread going...so keep watching ... Iíve learned a lot
Bryan & Vonnie MATHIESEN
Hollister MO
Retired 2011
2017 SUNSEEKER MBS 2400W
2013 HONDA FIT SPORT
psgrandpa1 is offline   Reply With Quote
Old 02-13-2018, 12:00 PM   #13
Flybob's Avatar
Check to see if there isn't a small lever on the AC ceiling vent that can be moved to close the dump valve.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-13-2018, 12:58 PM   #14
Mtnman64's Avatar
[QUOTE=Flybob;1730500]Check to see if there isn't a small lever on the AC ceiling vent that can be moved to close the dump valve.[/QUOTE Yes, close the main cover and force air out the duct work. That will help some, but the unit sits in the middle of the living space and IS NOT quiet !! It's not like the HVAC in your home for sure. I kinda get use to it after the first month on the road.
Mtnman64 is offline   Reply With Quote
Old 02-13-2018, 01:30 PM   #15
If you put your fan on the auto position it will cycle off once it reaches your preset temperature. Ours is loud but it's tolerable. We also use the slide on the big vent to route the air to the smaller vents. Auto does help.
Desertsquid is online now   Reply With Quote
Old 02-13-2018, 01:36 PM   #16
Angry
Originally Posted by Duckogram View Post
Donít know what type of A/C you have but if itís a BriskAir II, they are LOUD. My new coach has the Atwood w/heatpump and it is super quiet.
Good luck with that Atwood Heat Pump.....it cools great but the heat pump is garbage....It is how they programed it to work....their customer service agents would not keep a job at the drive thru at McDonalds....Mine will not stay running long enough to heat my 32' fifth wheel in Florida in the winter. I made an expensive mistake swapping out my Dometic AC.....so do not expect much from the Atwood, in heat mode the fan never shuts off and never satisfies the thermostat ....Atwood says it is supposed to work that way.....I told them that was BS because I went to school for A/C....
Bob Vaughn is offline   Reply With Quote
Old 02-13-2018, 01:43 PM   #17
psribbens
Compare to another unit at dealer
In addition to having the dealer listen to your unit, ask if you can listen to another similar unit on the lot. IMHO the HVAC's are pretty common even if not the exact same interior layout...
Don't know how technically inclined you are... but when I was investigating the noise issue with my 3011Ds I found a free android app called FFTwave. I used it as a sound power level meter. Test drove another 3011DS and found out the ambient running noise was about the same.
My HVAC unit is "noisy" too, and it's in storage so I can't tell you how noisy. However, from your description a visit to the dealer is in order.
Good luck!
Forester Ford E450
2017 3011DS
pribbens is offline   Reply With Quote
Old 02-13-2018, 03:43 PM   #18
psgrandpa1's Avatar
Are we supposed to just TOLERATE NOISE
I guess I wonít put earmuffs away this winter.
Iíll need them in SUNSEEKER to stay sane.
WHAT IS EVERYONE DOING TO REDUCE THE NOISE??
Hollister MO
Retired 2011
Old 02-13-2018, 04:25 PM   #19
Empty Nesters
KenandCarol's Avatar
Nothing. Everything is fine in mine and the noise is not disruptive at all.
2017 2250S Sunseeker.
2017 Sunseeker 2250 24' MH
KenandCarol is offline   Reply With Quote
Old 02-13-2018, 04:30 PM   #20
psgrandpa1's Avatar
Do you know what brand ac you gave
Domestic or Atwood
Hollister MO
Retired 2011
generator, noise, pump
