Old 01-18-2019, 08:07 PM   #1
Noise coming from battery area.
I have a 2014 3010DS and when it is quiet I hear a “clunk” sound around the step. Sounds maybe like a solenoid. Unit is parked and jacks are down. Only happens now and then and only 1 clunk at a time.
Mike3393 is offline   Reply With Quote
Old 01-18-2019, 08:52 PM   #2
cavie's Avatar
What are you doing when you hear this clunk?
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 01-19-2019, 10:53 AM   #3
In my 2017 2861, I hear the solenoid in the BCC operating to charge the engine battery. The BCC (Battery Control Center) is located on the side of the lower step. The BCC decides when to close the relay depending on the voltage of the engine battery and the charge voltage available from the converter when on shore power.
2017 Forester 2861DS
towing 2015 Jeep Rubicon
fobagbob is offline   Reply With Quote
battery, noise
