Old 03-16-2019, 10:33 PM   #1
Occasional use an water system
When using the MH on a one weekend a month schedule, summer months, are there any special procedures necessary to keep the water system clean?
What about heat and humidity control of coach when parked?
C5er is offline   Reply With Quote
Old 03-18-2019, 12:01 PM   #2
retireearly's Avatar
As long as you are using chlorinated tap water I think you are fine, I have done this for years with no issues. If it is more than a month I would dump and refill the fresh water tank. I never re-sanitize during the season though, there is plenty of residual chlorine. If I was using untreated well water I would be more careful.
2017 Forester 2291S
2015 Honda Accord on Master Tow Dolly
retireearly is offline   Reply With Quote
Old 03-21-2019, 01:31 AM   #3
Kirk S's Avatar
We keep our Forester at home and plugged in to 30 amp shore power.
I have a hydrometer/ thermometer to monitor the humidity and run the air conditioner or heat as needed throughout the year in south Georgia. We try to keep the humidity in the 45 to 55% range.
When we don't plan to travel we empty the fresh water tank and put the water filters in the fridge to hopefully inhibit mold growth.
We sanitize the tank and water lines annually. Probably overkill.
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
Old 03-21-2019, 08:34 AM   #4
Shredder's Avatar
I leave my RV in storage in summer month's at a time in the hot summer but make sure to drain all the water. Every time i use is it i put a little bleach in the holding tank mixed with water and run it through the system just to freshen it up.
But thats just me..
2013 Forest River Sunseeker 3010DS
Shredder is offline   Reply With Quote
Old 03-21-2019, 11:10 AM   #5
Kirk S's Avatar
I'm a victim of auto-correct and didn't catch the error. The post should read "hygrometer", not hydrometer.
Although I do have a battery hydrometer .
Kirk
2017 Forester 3051S
Old 03-24-2019, 07:53 PM   #6
sgtlm17's Avatar
We also use Camco TastePURE Drinking Water Freshener. It is basically chlorine to kill bacteria. We have an in-house water filter that filters the water from the fresh tank before it gets to the faucets.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 03-24-2019, 07:58 PM   #7
Flybob's Avatar
Not sure how bad humidity is in a Wisco summer, but in Maryland it is high. I use a 30pint dehumidifier with the permanent drain run through be floor. I have a wireless temp/humidity sensor in it and base station in the house. The need to drain your water or not will depend on the quality of the water supply. Chlorinated city water should be fine, however some well water can be problematic.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-25-2019, 08:47 AM   #8
Hoglou's Avatar
chilled filter
Ditto on hilling the filter. Our drained filter goes in the freezer while we are home.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 03-25-2019, 09:19 AM   #9
western NC mountains!
formerFR's Avatar
while most of us have an inline or whole house water filter that tank water is going to pass thru when you fill it, the water sitting there in your tank for long periods is not going to 'go bad', as there's nothing to make it go bad...
but, also, unless you are drinking your 'old' water tank water straight, it's really a none issue - most any of us are only using it in the shower, the kitchen sink, or if used in the coffee maker, it's being heated enough to not be any issue anyway.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx,
90,000+mi, US, Alaska, Canada, western NC for now : )
formerFR is offline   Reply With Quote
Old 04-01-2019, 06:08 PM   #10
Thanks for all the answers, I think i know how to proceed on the water. Unfortunately we store at a remote lot with no power, I was debating if i should connected a solar panel and leave a vent fan under the maxxair cover venting all the time, vs just closing things up.
water
