09-08-2014, 09:54 AM
#22
Originally Posted by OldCoot
Next project is to find a way/place to hang my 6 new self retracting ratchet straps in the basement ceiling and clean out all the other ratchet straps, junk.
Got that task out of the way. Now, I am finished.
09-08-2014, 09:58 AM
#23
Yea Right!
Started Out With Nothing,
Still Have Most Of It Left!
09-08-2014, 09:59 AM
#24
Now that's the way to do it; a picture of the mod!
09-08-2014, 10:30 AM
#25
NICE! I ment to ask you at Goshen - what do you store in the PVC tubes in your basement?
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
09-08-2014, 10:49 AM
#26
The awning sun screens. 2 are for the front main screen and the 2 end screens.
BTW, did you get your roll out drawer mounted and the laundry board finished?
09-08-2014, 11:54 AM
#27
Originally Posted by bgilly
Have you seen this. Its pretty slick, easy on and off.
Bodiak Hitches
Dave
Dave, Dawn, Lisa, and Jiggs (Boxer Furr Baby)
2014 Days Camped - 29
2014 Wildwood X-Lite 251RLXL
2014 Dodge Ram 1500 Longhorn, 4X4, 5.7L Hemi, 8 Speed Auto, 3.21 Rear, Air Leveling Suspension
09-08-2014, 12:20 PM
#28
NELA
Keep that up and it'll look like all those 363 clamps ya got hangin' in your shop.
Have you tried the six footers yet (on the pole) to see if they're long enough if you go straight down to the earth anchor?
(makes note to self to call Bobby and see if he picked up the 8 footers for us this weekend)
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
09-08-2014, 12:27 PM
#29
Originally Posted by Weezer
...Have you tried the six footers yet (on the pole) to see if they're long enough if you go straight down to the earth anchor?...
No, I haven't, will determine that the next time we go camping. If the 8'ers aren't long enough, I may have to use 2 6'ers to get far enough out. We'll just have to see.
09-08-2014, 04:26 PM
#30
Bobby,
Get going on that front hitch, I want to be second in line....
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
09-08-2014, 05:44 PM
#31
Well, like any project that involves research and experimenting - it needs funds. Donations gladly accepted!
09-08-2014, 06:48 PM
#32
In the water filter bay the black tank in the ceiling is the black water tank correct? And the pex line running into it (the top lefts side) is the flush line correct?
Feel'in like a mod is coming on..... As the flush hose fitting is directly behind the sewer bay door on my unit, cant run the sprayer with the door hooked open PITA.
Maybe hard plumb a spray line with check valves to full time water supply with cut off. Would never have to hose up the black sprayer again...
09-08-2014, 07:24 PM
#33
I'm thinking if yours is like my 3171 the black tank is to the right (from the water filter compartment), the grey waste tank is to the left. If you remove the vertical panel with the access door, you will be able to remove the top cladding around the tanks. From there you can look up and you will see the black tank flush nozzle on the side of the tank. It will be easy access to the water filter pump stuff. I would be cautious - even with valving to to the flush system you don't the physical separation of one hose to the coach and one hose to the flush system.
Bobby
09-14-2014, 06:52 AM
#34
Oh no.... I have no next mod to do
[QUOTE=Hoglou;Everyone has done the seat storage mod right? adding a top access door for the area behind the drawer.[/QUOTE]
Regarding the area behind the dinette drawers
What do you use for a door I've thought about accessing this area thanks
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
09-14-2014, 07:42 AM
#35
Have no next Mod to do! The ONLY way this could be true is if you Sold the RV!! Youroo!!
09-14-2014, 10:40 AM
#36
we have the U shape dinette. I took the wood decking up (6 screws I think) from under the seat cushion behind the driver seat.. Added an extra 2x2 support running in the direction of front to rear bumper. pilot drill, wood glue, then screwed it togther. I prefer sheet rock screws. Cut the decking in half with the center line of the cut over the new support. screwed down the front peice over the drawer, and added a thumb hole for the access door. It will hold about a milk crate's worth of new stuff.
09-15-2014, 12:38 PM
#37
My next mod is to turn my TT into a new class A!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
09-15-2014, 03:36 PM
#38
*Grumble* Rig is still at the dealers ... this JT Strongarm install is taking a LOT of time - in order to do it right, the Tech is welding angle iron to the frame to mount the JTs and is having to fit the welding in between other maintenance stuff (I am sorta low on the totem pole at this dealer )
Oh well, at least I have OC's basement tray stained and painted need to swing by the shop and get the laundry board out of the bumber soI can stain it as well.
09-15-2014, 03:49 PM
#39
They still haven't got those JT's on for you yet? They were supposed to install those back in Goshen! You know, maybe it's a sign that it's just not meant to be. Gonna have to go with something else.
BTW, when you do get the laundry board, don't forget to send some pics. DW's still waiting for visual confirmation before approving this winter's project.
09-15-2014, 04:01 PM
#40
Originally Posted by Kaadk
...BTW, when you do get the laundry board, don't forget to send some pics. DW's still waiting for visual confirmation before approving this winter's project.
Very similar to this one.
