Originally Posted by sgtlm17
Speaker C is for the subwoofer. Put something on that has some good bass and select and deselect C and you will hear the subwoofer.
do you have the Jensen JWM6A in your motorhome and What year is it.
I have a 2017 MBS 2400WS with a Jensen JWM6A
The JWM6A DOES NOT have a sub woofer channel
It has three sets of LEFT/RIGHT channels available in its design
The "A" channel outputs consist of a L Front/R Front and a L Rear/R Rear that are located in the main cabin area
The "B" channel outputs consist of a L and a R speakers located outside
The "C" Channel outputs consist of a L and a R
On my radio the "L" channel has a lamp cord style green/white wiring hooked to it. the wiring runs up into the ceiling somewhere but is not connected to anything.
The "R" is not connected to anything.
I know all of this because I finally got around to checking out the dvd player in the JWM6A yesterday and found out that the factory never hooked up the HDMI cable so I had the unit out.
If you have a problem believing what I say is true. Here is the manual for the Jensen JWM6A as proof.
