Old 10-17-2014, 11:14 AM   #11
Originally Posted by f1100turbo View Post
Should have absolutely nothing to do with a printed circuit board!
If there's "moisture" on the circuit board there's an issue within how it's sealed from moisture which has no effect on how many hours it runs.
Turbs
Agreed but my dealer indicated regardless of issue they are going to check the hours. Just trying to give people a way to avoid a fight and learn from oldnewguys experience.
2015 Sunseeker 3170ds
TakeItEasy is offline   Reply With Quote
Old 10-17-2014, 01:05 PM   #12
Onan can do this when they are the only game in town. Since Genrac went out of the RV business I believe Onan is the only manufacturer left, at least that's what I read on here.
ATVer is offline   Reply With Quote
Old 10-17-2014, 10:05 PM   #13
mshell56118's Avatar
Originally Posted by oldnewguy View Post
Have a 2013 3050s with a onan 4000 generator in it. took it to repair shop because gen would not start, told a new control board was needed as the one in there now shorts out the fuel pump. i have 10 hours on the gen, was told by repair shop not enough hours for item to be covered. manual says to run it 2 hours a month to keep it under warranty just a heads up for everyone to follow the manual and avoid this costly mistake keep on camping oldnewguy
I work for cummins which is Onan we have never denied warranty and neither can they unless the can prove that the non running is what caused the issue.
I would call the cummins distributor in your area or direct http://power.cummins.com/onanpowerWe....do?pageId=505
Sent from my iPad using Tapatalk
mshell56118 is offline   Reply With Quote
Old 10-17-2014, 10:24 PM   #14
B and B's Avatar
I believe the circuit boards are dipped in either expoy or some other slant. The Onan Generators I have worked on at Transmitter Sites had sealed boards and we NEVER run 2 hours a month, all diesel though and we added conditioner and did run a day a year to burn the furl off.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 10-17-2014, 11:54 PM   #15
TURBS's Avatar
That's my point.
Turbs
Old 10-18-2014, 07:19 AM   #16
Hopefully, the RV dealer didn't bill Onan and pocket your $950.
biznsa is offline   Reply With Quote
Old 10-18-2014, 07:26 AM   #17
This is in regards to exercising the generator. I have an Onan 4000 Juice Box. I've had it since 2009 when I bought it new. I have 491 hours on it. When I'm done for the season, I fog it, change the oil and drain the carb. It then sits in the shed from the end of October to May before it gets started again. When I first got it, I exercised it but stopped doing that after the place I bought it from told me to fog it. I've never had a problem with it other than a recall. It is a portable unit and is attached to the 5er at the rear via a trailer hitch. Just my experience with mine.
Pipeman is offline   Reply With Quote
Old 10-19-2014, 09:58 AM   #18
onan 4000
right now my motorhome is wanting for parts. the repair shop is a dealer for onan products, but i wll cintact the main company about my problem. this forum is the best thing since slided bread keep on camping oldnewguy
oldnewguy is offline   Reply With Quote
Old 10-19-2014, 11:04 AM   #19
mud yapster's Avatar
We are dry camping in our pasture this weekend to see how the 5er acts and to identify any issues. Well after the auto leveling and opening all slides I ran our new Cummins 5500 watt genny for 1 hr just to let battery charge up good. That was Friday, Saturday I did the same ran it for 1 hour, this morning I ran it to make coffee and top off battery it died twice after running for about 15 min. Both times it would restart after waiting a couple min. The third time it ran fine for 30 min. With coffee maker and electric heat on fireplace on. Weird.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 10-20-2014, 07:05 PM   #20
Does it seem to be overloaded? Is water heater electric on? Is refrigerator on auto? If on auto switches from gas to electric when the generator runs.
RamblerGuy
2011 Sunseeker 3100
1997 Pathfinder Toad
generator
