Old 11-05-2014, 02:28 PM   #21
did not want to leave this one open. talked to onan about my repair . they said a ky generator has a three year thousand hour warentry on it, they are working on getting my money back on my repair. they want you to run it two hours a month with a 3/4 load, but if it will not run , how can you do that. at least someone is trying to fix my problem keep on camping
oldnewguy is offline   Reply With Quote
Old 11-05-2014, 02:39 PM   #22
mud yapster's Avatar
Originally Posted by mud yapster View Post
We are dry camping in our pasture this weekend to see how the 5er acts and to identify any issues. Well after the auto leveling and opening all slides I ran our new Cummins 5500 watt genny for 1 hr just to let battery charge up good. That was Friday, Saturday I did the same ran it for 1 hour, this morning I ran it to make coffee and top off battery it died twice after running for about 15 min. Both times it would restart after waiting a couple min. The third time it ran fine for 30 min. With coffee maker and electric heat on fireplace on. Weird.
Sorry I forgot to up date. I found my fuel line running under my RV smashed off in 2 places not giving me fuel flow. I fixed the brackets holding the fuel line to restore the fuel flow. I restated the genny and it works perfectly now.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 11-05-2014, 10:11 PM   #23
mshell56118's Avatar
So glad giving them a call is going to help you out. I knew that did not sound correct
Sent from my iPad using Tapatalk
mshell56118 is offline   Reply With Quote
Old 11-06-2014, 08:40 AM   #24
trdutch's Avatar
In order to keep the required 2 hours minimum for the warranty, you obviously have to be able to run it year round
In the off season I fill the Gas tank and add favorite additive Seafoam and run the gen monthly all winter
The Seafoam not only stabilizes the the fuel in the tank and keeps moisture from forming,but keeps the gen sets fuel system and all the components clean.
Get that money Back!
Run that Generator!
They are designed to run
My old Fleetwood had 630 hours on it and it started easier than the one on my new Sunseeker
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 11-06-2014, 09:15 AM   #25
With a 3 year or 3000 hour warranty you can bet they are well built and made to run it won't hurt one bit to run it 24/7 year around if you have the fuel to do it. Just keep up the maintenance on it you will never need another one. My buddy has over 4700 hours on one without a hick-up.
Old 11-06-2014, 12:02 PM   #26
Onan
The tech that did my walk-through on my new 3050s last month made a statement that I did not pick up on at first. He stated "Never start the Onan with the power card plugged into the AC pedestal". I have seen many "A" class RV's started while plugged in.
J. V. is offline   Reply With Quote
Old 11-07-2014, 04:38 AM   #27
The owners manual does say to run it every month to keep it exercised which is something that won't happen since people don't exercise their own body. LOL
Old 11-07-2014, 07:21 AM   #28
I never use the generator and am thinking about removing it to reduce weight. However if I did I would probably need it. I maybe have 2 hours on it. Thus after the first summer I disconnected the fuel line, ran it dry, fogged the engine, and plugged the exhaust. Other than spinning it over on the starter once in a while it just sits. The coach is stored inside a dry building except while camping so I'm not concerned about moisture.
ATVer is offline   Reply With Quote
Old 11-07-2014, 07:22 AM   #29
onan 4000 generator
There's also instructions in the owners manual on prepping it for storage if the genset can't be exercised.
biznsa is offline   Reply With Quote
Old 11-07-2014, 07:46 AM   #30
Thanks I never noticed that in my manual. Have to check it out but I have a Genrac not an Onan.
generator
