Old 11-09-2014, 01:28 PM   #1
rsscully's Avatar
Onan generator hour meter.
My generator has very low hours on it, maybe 30. The last two times I have run it the hour meter has not worked. The hour meter does not show anything anymore. Pulled the panel and have ~12 volts on either side of the meter when not running. When I have the genny running I only have ~12 volts on one side of the meter. Is this normal? Any ideas? Is the meter just bad?
rsscully is offline   Reply With Quote
Old 11-09-2014, 03:37 PM   #2
On side should be positive..other side ground.. You should only have 12 volts when gen set is running...
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 11-09-2014, 03:40 PM   #3
This may help..
http://www.justanswer.com/small-engi...eter-does.html
Old 11-09-2014, 04:32 PM   #4
rsscully's Avatar
Thanks Jester. I actually read that already. The light works, the terminals have voltage but no display.
Old 11-09-2014, 04:58 PM   #5
Is your gauge analog or digital?
Old 11-09-2014, 05:08 PM   #6
rsscully's Avatar
Digital.
T44 Series LCD Hourmeter, EEPROM Memory On ENM Company
Old 11-09-2014, 05:13 PM   #7
What I find strange is you have 12 volts on both sides... I don't believe you should have any power to the gauge unless unit is running....
Old 11-09-2014, 05:26 PM   #8
Do you have a hr meter on gen set it self... Is the dc fuse intact?
Old 11-09-2014, 08:04 PM   #9
It's possible that starting the generator applies a ground to the negative side of the meter. If that is the case you would read 12V on both sides when the generator is not running. I think you have a bad meter.
David, Sherry and our three fur kids, Nicholas, Finnegan and Bentley
2013 Coachmen Encounter 36BH
2014 Honda CR-V/ Blue Ox Patriot II
DSurette is offline   Reply With Quote
Old 11-09-2014, 09:36 PM   #10
x2 on a bad meter.
ATVer is offline   Reply With Quote
generator
