07-15-2015, 07:16 AM
#21
Georgia Rally Coordinator
Thanks for the info. Don't think I'd get one that you hard wire. I like to be able to use else where.
Baldicon Is the progressive IND a 50 amp? Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
07-15-2015, 07:36 AM
#22
Yes you can get either a 30A or 50A.
07-15-2015, 04:03 PM
#23
Originally Posted by hockeytownmom
I have the Progessive Industries portable ($270.00 ish) protector.
Wow, $270 sounds high. I saw a 30 amp portable one for $89.90 from Progressive Industries. Won't that do the trick for our 2016 3171DS?
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
07-15-2015, 05:05 PM
#24
The more expensive one is an electrical management system with surge protection. Highly recommended it.
Snyder Family - Pelham, NH
2015 Sunseeker 3170DS
07-15-2015, 08:17 PM
#26
Wait till next year...
More protection on the EMS-PT30c . I installed the EMS-HW30 under the rear bed. It has a neat remote display with current draw and voltage displays. Cheap insurance that you wont run into a bad power pole
Mary and Me
2015 2650s "Finally" SOLD
2015 Jeep Cherokee Toady
2023 Geo Pro FD19 "Almost there"
2022 Race Car Red HR Long Ford Transit 250 "The Iwish Roamer"
07-15-2015, 09:25 PM
#27
Citrus County, Fl.
Ben the EMS HW30C is the one you want. As others have said, it does so much more and it has a lifetime warranty. Just wish Forest River would have had them as an option. I got mine from Best RV and Truck Supply for $232.47. Good people to deal with. 888-828-1893
2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
07-15-2015, 10:15 PM
#28
The portable works just as well. Hardwired or portable, the EMS version is the way to go. Wouldn't leave home without it.
07-15-2015, 10:31 PM
#29
We have been PI EMS equipped (hardwired) since 2010 when a surge at a local CG damaged our power converter panel. Our Aliner and TT have had them ever since and saved us from damage twice. It is also nice to be able to monitor power usage in the camper (the Progressive units read out volts, instantaneous amps, and trouble codes).
07-16-2015, 12:51 AM
#30
Originally Posted by Yorkranchgalnguy
We don't have an electrical compartment - the plug goes right into the out side wall of the motorhome. Did they change that on thr 2015 or 16 3170 ds? Would love to be able to lock plug and surge protector out of the weather.
I was thinking the same thing, but thought I could run the plug (from the MH) through the sewer hole and keep the protector in that compartment and the spare line end through the same hole to the pedestal. Sorry, too late for technical terms!
Kristina
2016 Rockwood Premier 2317G
2021 F150 XLT
Previously:
2005 Fleetwood Seapine, 2012 Rockwood Roo
2015 Sunseeker, 2017 Fleetwood Pace Arrow
07-16-2015, 01:30 AM
#31
Hardwired is the only way to go!!!
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
07-16-2015, 04:07 AM
#32
I would say hardwired or portable, progressive EMS is the only way to go.
I have mine like others have stated. 30amp extention cord from pedistal to EMS, EMS to trailer power cord. I lock my EMS-PT30C to the steps under the awning so I can monitor it from outside where I spend most of my time.
crunchman
2015 F-250 FX4
07-17-2015, 07:20 AM
#33
I hardwired my PI EMS under the bed and after the transfer switch. That way it also gives me readings on what the generator is doing when we are being powered by it. Yes, it leaves the transfer switch exposed to surges, but the benefit IMHO of seeing what the generator is putting out is worth it. Mounted the display just under the circuit breaker panel, which is on the front of the bed facia.
2012 Forest River Sunseeker 2300 Chevy
07-17-2015, 10:13 AM
#34
Mounted mine under the cabinet behind the breaker/inverter box, and display on side of cabinet just inside the door. That way I can plug in and see if there is a problem before I set up. Also wired in twist lock plugs on the line and load side of the EMS. If I have a problem with the EMS, all I have to do is unplug both sides and plug the incoming line directly to the load going to the breaker/inverter and bypass the EMS.
07-17-2015, 04:37 PM
#35
I have a portable surge protector, the main cord is under the bed and I wired a plug and receptacle into the main cord and plug the surge protector inline that way it easy to transfer to another RV.
