Old 07-16-2015, 01:30 AM   #31
SYE
SYE's Avatar
Hardwired is the only way to go!!!
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 07-16-2015, 04:07 AM   #32
crunchman12001's Avatar
I would say hardwired or portable, progressive EMS is the only way to go.
I have mine like others have stated. 30amp extention cord from pedistal to EMS, EMS to trailer power cord. I lock my EMS-PT30C to the steps under the awning so I can monitor it from outside where I spend most of my time.
crunchman
2015 F-250 FX4
Old 07-17-2015, 07:20 AM   #33
I hardwired my PI EMS under the bed and after the transfer switch. That way it also gives me readings on what the generator is doing when we are being powered by it. Yes, it leaves the transfer switch exposed to surges, but the benefit IMHO of seeing what the generator is putting out is worth it. Mounted the display just under the circuit breaker panel, which is on the front of the bed facia.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 07-17-2015, 10:13 AM   #34
Mounted mine under the cabinet behind the breaker/inverter box, and display on side of cabinet just inside the door. That way I can plug in and see if there is a problem before I set up. Also wired in twist lock plugs on the line and load side of the EMS. If I have a problem with the EMS, all I have to do is unplug both sides and plug the incoming line directly to the load going to the breaker/inverter and bypass the EMS.
Baldicon is offline   Reply With Quote
Old 07-17-2015, 04:37 PM   #35
I have a portable surge protector, the main cord is under the bed and I wired a plug and receptacle into the main cord and plug the surge protector inline that way it easy to transfer to another RV.
edcronin01 is offline   Reply With Quote
