Originally Posted by texasblues
Anyone know if there is an inline water shutoff valve for the outdoor shower on a 2015 Sunseeker 2800 QS? It looks like I might have a water leak in the wall beneath the shower.
Non on our 2013 2500TS,,,
We had to remove the shower box when our unit was new,,, could not get any Hot water,,, we found that the non flexible supply line to the hot water was pinched off,,, after removing the line I heated it up with Hot water,,, then set it with Cold water,,, to remove the knick !!!
It was a little tricky getting it back in without pinching it again,,,
it could not be jammed back in like FR had done !!!
Our first FR TT we had a water leak inside where the fresh water fill was,,,
Hose clamp was loose !!!
