Old 09-13-2014, 11:41 AM   #1
Outside cable hookup not working
When I hook up to the outside cable connection it is not connecting to the tv. If I run the cable directly to the tv it works fine so I'm pretty sure there is a problem from the outside hook-up? Has anyone had a problem like this? I tried doing a search but couldn't find anything. I have a 2014 Sunseeker 2650ts. Thanks
mitchpadl is offline   Reply With Quote
Old 09-13-2014, 12:08 PM   #2
H2oski
Did you turn OFF the antenna booster? I it is ON your tv will not work on cable.
Good Luck
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 09-13-2014, 12:14 PM   #3
Ford Idaho's Avatar
Do you know if your unit has a signal splitter?
Old 09-13-2014, 12:42 PM   #4
asquared's Avatar
Good Luck
This
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 09-13-2014, 12:42 PM   #5
a signal splitter is the problem
Gee Whiz is offline   Reply With Quote
Old 09-13-2014, 03:50 PM   #6
tmhyer's Avatar
Booster must be on
tmhyer is offline   Reply With Quote
Old 09-13-2014, 04:05 PM   #7
Evereddie's Avatar
Originally Posted by tmhyer View Post
Booster must be on
Uh, NO. The booster must be off for the cable connection to work. The booster switch actually switches which input goes to the TV. With the booster switch turned ON the antenna signal goes to the TV. With the booster switch OFF the cable input on the side of the trailers goes to the TV.
But, some trailers including mine have had the outside input for the cable switched at manufacturing with the AUX input that brings a satellite dish signal into the trailer. If you turn off the booster and the cable input still doesn't work, try the AUX input.
Evereddie is offline   Reply With Quote
Old 09-13-2014, 04:21 PM   #8
tmhyer's Avatar
Right, he must have the booster on. That is why it isn't working :-)
Old 09-14-2014, 06:29 AM   #9
trdutch's Avatar
I know I forgot about it the first time I used the camp cable
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 09-14-2014, 07:07 AM   #10
fonzie's Avatar
On my unit I have a cable" in" on the driver side and a cable "out" on the passenger side of the trailer, something to check.
Fonzie
