Old 12-30-2017, 05:22 PM   #1
Hoglou's Avatar
outside shower cutoffs
New project, no longer winterize the outside shower as I swapped out the feed lines with ones with cut off valves. Parts and pics are posted in my water works album.. Spent more time picking out the parts at Lowes then doing the actual work. It helped to loosen the shower line back caps for install. Also used the factory washers on the valves connected to the sink lines. The lines to the shower came with a seal.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 12-30-2017, 05:30 PM   #2
herbike's Avatar
Now you got something else I think I should do. Sounds like a good idea. We seldom use our outside shower too.
Thanks for the idea!
Days camped in 15-180 days-16-95 days
17--114 days-18-71-days
19-32
2016 t28FQDX Shockwave, New Provider tires 10/31/18 ,TV-2015 LTZ Duramax with over 151,000 miles, with delete done, 2014 Polaris RZR 800 EPS/ 9800 miles
herbike is offline   Reply With Quote
Old 12-31-2017, 12:28 PM   #3
Wandering's Avatar
Wow! Thanks! Your solution is much better that my cap the supply line approach. I’m off to Lowe’s
Forester 2451s
Wandering is offline   Reply With Quote
Old 12-31-2017, 09:59 PM   #4
Kirk S's Avatar
Thanks!
Sounds like what I'm planning to do.
Where would I find your water works album?
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
Old 01-01-2018, 03:05 PM   #5
Hoglou's Avatar
album access
Click on my name Hoglou above my dapper self portrait on the left side of the post. Go to my public profile, it is the first item. My albums are on the bottom rightside.
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Old 01-01-2018, 04:31 PM   #6
Prime Member
It takes me an extra 30 seconds to winterize the outside shower. Not worth the time and effort to install valves IMO.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 01-10-2018, 06:06 PM   #7
Wandering's Avatar
ID:	159927Click image for larger version
Thanks! Hoglou
Installed the bypass valve for my outside shower. Appreciate you sharing. Hoping to head out next week for some winter camping and won’t need to worry about the shower.
Forester 2451s
Old 01-11-2018, 05:30 PM   #8
Hoglou's Avatar
pic quality
Nice... But be sure to pressure up with shore water pressure for proper leak inspection before checking this off your list. Your work pics are far superior to mine, I might harvest them with your premission.
I was often concerned about the outside shower freezing when we winter camp while using water, mostly when we were laying in bed about 3 am and realizing just how dang cold it was outside, well no more....
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Old 01-11-2018, 07:22 PM   #9
Wandering's Avatar
Yes, got them pretty tight but will worry for a couple weeks about leaks once I get water in it, especially when hooked up to city water. Probably won’t see water till we head south, snow and single digit temps this weekend.
I froze the shower and had to replace it once already. Will probably stick a little insulation in the outside compartment just to keep the camper warmer.
Feel free to use the pictures as you wish.
Thanks again, way better than my original plan to just cap the water line then reconnect when I wanted to use the shower again.
Forester 2451s
Old 11-13-2018, 09:36 PM   #10
Wandering's Avatar
Just an update. Last January we camped out west and temps got down to 4 degrees. Glad I isolated the shower as there is no way to keep it above freezing.
Forester 2451s
show, shower
