Old 03-25-2019, 03:02 PM   #1
Bonjoey's Avatar
Outside speaker how to access
I found out one of the outside speaker is not working in our coach. Checked the wires in the headunit and itís fine. Trying to access the outside cover, there are 2 tabs/slots on one corner but cant figure out how to open it, and dont want to break it. Any help?
2019 FR Sunseeker 2650S E450SD
Bonjoey is offline   Reply With Quote
Old 03-25-2019, 03:19 PM   #2
RV There Yet?
IsleDog's Avatar
Can you post a picture so that we can see what you are working with? Make and model of camper would be helpful too.
2018 17RP
2009 Crew Cab King Ranch F150 "Goose"
IsleDog is online now   Reply With Quote
Old 03-25-2019, 07:45 PM   #3
Bonjoey's Avatar
2019 2650s
Picture attached
Old 03-25-2019, 10:04 PM   #4
The solara awning speakers (I should say poor excuse for speakers) can be accesed by removing the back cover of the speaker/motor housing. There are 5 screws in recessed holes on the back side.
Looking again it appears they may have changed the design a bit from what I have disassembled.
2017.5 Forester 3051S
2016 Honda Accord
Steve-W is offline   Reply With Quote
Old 03-25-2019, 10:06 PM   #5
Bonjoey's Avatar
Originally Posted by Steve-W View Post
The solara awning speakers (I should say poor excuse for speakers) can be accesed by removing the back cover of the speaker/motor housing. Ther are 5 screws in recessed holes on the back side.
Oh? So i have to extend tha awning to access the screws. Thx
Old 03-25-2019, 10:10 PM   #6
Yes and get on a ladder above the housing.
2016 Honda Accord
Old 04-04-2019, 01:06 PM   #7
Bonjoey's Avatar
Got the cover out and it seems wires are intact but still no sound coming out. The outside speakers are connected to B and only the Left is working. Any other idea what to check? Cant see behind the wall to check the wires.
Old 04-04-2019, 01:11 PM   #8
Did you put a meter on the wires at the speaker to see if you had power there?
MtBiker is offline   Reply With Quote
Old 04-04-2019, 05:57 PM   #9
The wires are most likely spliced where they enter the coach. Slices will be stuffed inside the hole that the wire feed through. You will find a plastic cover that runs the length of the arm section that is attached to the coach. most likely near the bottom of the arm.
The plastic cover can be removed probably held in with sealant/RTV.
2016 Honda Accord
Old 04-12-2019, 07:02 PM   #10
dcheatwood's Avatar
The speakers in my solera awning (Forester) have right/left adjustment in the audio settings. Have you checked to make sure it's not just turned off?
2018 Forester 3011 DS
