Old 03-19-2019, 07:18 PM   #1
Outside Tv
I have a 2013 Sunseeker 3170. Does anyone know how to remove the TV in the outside entertainment center?
CSHelm is offline   Reply With Quote
Old 03-19-2019, 07:41 PM   #2
AudiDudi's Avatar
If it's like the outside one in my Prism, you need to remove 4 screws as I recall.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is offline   Reply With Quote
Old 03-19-2019, 09:52 PM   #3
Usually Confused Member
emm-dee's Avatar
Hold on the the TV at each outside edge on the very bottom. While pulling upwards very firmly do a slight left/right rocking motion where your hands are. The TV will slide upwards in the mount (that you cannot see) until the pins clear. Comes right off. Oh, did I say firmly pulling up? Yep, it's tight but will come out.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Old 03-20-2019, 01:01 PM   #4
Just curious but has anyone ever tried to replace the current outside TV mount with a swivel arm?
ksdindy is offline   Reply With Quote
Old 03-20-2019, 01:47 PM   #5
emm-dee's Avatar
I’d like to but there’s only about ˝ inch clearance when the door is closed. Swivel mounts usually use more room than that.
Old 04-20-2019, 02:24 AM   #6
Thank you so much! That worked!
