Old 05-04-2015, 12:48 PM   #1
Outside TV Audio only thru TV Speakers?
Just picked up our 3050. Love it. One issue I can't seem to solve. I want to play the outside TV audio thru the speakers. I looked at the TV and the audio out is going to the radio. Changing the Source to TV, I would expect it to work, but it doesn't. Anyone solved this riddle yet?
trnarg is offline   Reply With Quote
Old 05-04-2015, 04:59 PM   #2
Make a list ,keep a copy, make apt for dealer to remedy the list, if not purchased from a dealer,call former owner ask them also.
Happywanderer is offline   Reply With Quote
Old 05-05-2015, 06:21 AM   #3
Update for anyone reading. The menu on the TV has to be set to TV speakers off under audio and under set up turn audio out to fixed. Also, I think the dealer had the AV connection into the radio wrong. Just need the one video line and the two audio out lines from the TV. For some reason, I can't get the TV speakers and the radio speakers to work at the same time.
Old 05-05-2015, 07:51 AM   #4
yetavon's Avatar
We had the same problem....the TV output was plugged into the IRV radio Output....DUH!!!! swapped to the input and set radio to TV Audio and works fine.
Retired Paramedic
2020 FSX 280RT
2005 Silverado 1500 Ext cab 5.3 H.O.
2011 HD Road King
Nights camped since 2019.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
Old 05-05-2015, 08:08 AM   #5
Thanks. Were you ever able to get the TV speakers AND the radio speakers to work at the same time?
Old 05-05-2015, 01:48 PM   #6
yetavon's Avatar
Yes, works fine with the antenna and DVDs, but if fed thru the front HDMI it has a slight delay in the TV speakers.
Retired Paramedic
2020 FSX 280RT
2011 HD Road King
