Old 04-23-2016, 07:11 AM   #1
2015 Sunseeker 2300
?? overhead bed and propane tanks.. wind noise
Does anyone know where I can find the weight limit for the sleeping area over the cab and the weight the ladder will support...
and does anyone know where I can find how much propane we hold neither of these are listed in the brochure or anywhere I can find on the Forest River page. Just wondering why Forest River is making this so hard to find Thanks for your help..
....by the way those that have wind noise like me...look at the bottom of your outside door I bet the rubber weather strip does not go all the way across..the dealer replaced this for me and now much quieter!
Gingsnap is offline   Reply With Quote
Old 04-23-2016, 08:56 AM   #2
I don't have numbers for the overhead bed, but the ladder has a weight limit label, and if I recall, ours is 225 lbs. The overhead bed is designed for two adults; I would suspect it'll handle at a minimum 2x the ladder load + mattresses & other items. I wouldn't be hesitant to put 500lbs+ up there.
Regarding the propane tank - Look on the tank itself - there's a metal label welded onto the tank. This will tell you the gallons.
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
Old 04-23-2016, 04:46 PM   #3
According to the 2016 brochure, the LP capacity is 9.8 gallons. It is listed with all the other specs.
Thanks for the heads up on the door weather stripping. I'll be sure to take a look at ours.
2016 Sunseeker 2300C
SS Cruiser is offline   Reply With Quote
bed, noise, propane, tank
