Old 04-20-2014, 06:57 PM   #21
I do not experience any sway. The air bags are at 60 psi and the tires are at the spec pressure 80 on the rear and 75 on the front. We travel on I95 at speeds up to 70 mph.
kswing60 is offline   Reply With Quote
Old 04-20-2014, 07:20 PM   #22
tmhyer's Avatar
Phelpo, usually between 65-70 mph. I keep the tires at the pressure on the sticker on the inside door, which I have to look at every time! I think the air bag pressure should help the sway.
Sent from my DROID RAZR using Forest River Forums mobile app
tmhyer is offline   Reply With Quote
Old 04-20-2014, 08:23 PM   #23
Garrette's Avatar
Originally Posted by kswing60 View Post
Installed the 5Star tune upgrade and what a difference. The transmission shifts much better. No more high RPMs. Going up hills it downshifts one gear at a time instead of dropping down two gears. After doing the install there was a check engine light. Read the diagnostic code and it was a RAM error. Contacted the vendor and the next day sent out a new tune program that resolved the check engine light. Overall we are very satisfied with the results and the customer service. Have not filled the tank after our last trip we went about 250 miles on a half tank of regular gas.
Please post web site for your 5 star tune. Thank you.
Garrette is offline   Reply With Quote
Old 04-20-2014, 10:09 PM   #24
Website is http://www.5startuning.com enjoy.
Deb and Ron
2015 Forester 3011 DS
Rzbot is offline   Reply With Quote
Old 04-21-2014, 03:46 AM   #25
More info on handling on the thread Sunseeker tire and airbag pressure
Old 04-21-2014, 07:32 PM   #26
Garrette's Avatar
And you. Plan to look into it. Do you know if it will harm the ford warrenty?
Old 04-21-2014, 08:34 PM   #27
Before taking it to a Ford dealer for service reinstall the factory program.
Old 04-21-2014, 09:00 PM   #28
owners of 3010ds and 3011ds how does your rig drive?
Ok, here's my experience with a 2012 3010ds. I carefully check the air pressure. Running 80 psi rear and 75 fronts. I also work on balancing the weight side to side. At 5000 miles I had the rig front end aligned. Amazing difference. I also run 65 psi in the air bags. A truck shop did my alignment in Delaware Ohio. Very good folks.
I have zero and I mean zero problems with semi's or large trucks. Believe it or not I will get a slight push from a full sized pickup or van only traveling in the same direction but nothing from a large truck in either direction.
It handles very well and I'm very happy driving it at whatever speed.
Tire inflation, air bag pressure which transfers some weight to the front axle, and front end alignment are the keys.
MikeRP is offline   Reply With Quote
Old 04-21-2014, 09:03 PM   #29
I also don't feel I need a tune. It takes a while for the motor to break in. Seems like it has plenty of power now at 9000 miles versus when I first got it. Out to Colorado last year it did great.
Old 04-22-2014, 03:43 AM   #30
The engine has plenty of power. We did not have a problem with that it was when the transmission was shifting that was the issue.
