08-04-2015, 07:42 PM
Parked for a while
So I haven't been traveling as much as I would like lately and my 3170ds has just been siting for a while. I regularly run the engine and the generator but the last time I tried to start the generator it hasn't started. The temperature has been warm and the battery level was fairly low so my question is, should the battery be charged more to get the generator to start? Also, if I am plugged into regular house power to charge the battery should the disconnect switch be set to in or off? Thanks for any help.
08-04-2015, 08:46 PM
Parked for a while
On. If your batteries are not strong enough to crank the generator then they are over discharged.
Also, you can tie your chassis battery to the coach battery temporarily using the switch located on the base of the driver seat (on mine) or on the dash on some. Takes two people, one on the spring return switch and the other starting the generator. You can also use this switch to start the engine off the coach batteries.
2014 Sunseeker 3050S
Honda CRV (TOAD)
08-05-2015, 12:26 AM
Our unit will charge the coach batteries with the switch on or off when on shore power. I think by running the engine for a short period then you should be able to start your generator. Switch has to be on for starting the gen.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
08-05-2015, 07:28 AM
For 2014, at least the early year models, they did not charge with disconnect in OFF, I believe that did change in later models.
Honda CRV (TOAD)
08-05-2015, 11:52 AM
If you have it plugged in then your batteries may be in need of water or changed
We just had a thread on bad batteries
My Indy RV repair guy said the batteries of today are really not great and 2years is good (all the recycled lead isn't giving the life they once did)
Interstate was making a pro series with new lead but demand was too low
All the penny pinchers out there would rather hassle with these problems than spend $30 bucks more for a good battery
Not being able to start my Gen set with what I thought were fully charged batteries is what set me on my quest to figuring out that my one year old 2860 had junk batteries even though I checked and filled the water and kept a charge on them
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
08-05-2015, 05:27 PM
I replaced my batteries the second season of camping. Went with true deep cycle Lifeline AGM batteries. So far so good.
Honda CRV (TOAD)
08-05-2015, 09:17 PM
Just plug it into the 120 volt house current and leave it plugged in. The batteries will charge and you can excerise the genny all you want. Just run the AC for a load. The more you run the genny, the better.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
08-06-2015, 07:21 AM
I'd like to get a definitive answer on whether or not my unit 2014. ('13 chassis) 2860 needs the battery switch "on" to charge while plugged in at the farm where it's parked
I don't want to waste electricity for all the plugged in items (TVs,Micro,clocks etc.and anything else that uses residual power)
'78.....tents
08-06-2015, 07:55 AM
If by "ON" you mean battery not disconnected then yes.
08-06-2015, 09:07 AM
Residual power use is minimal and there are loads such as battery controls, generator controls, slides, awning power etc that are directly wired to the battery and not shut off through the switch. If you are concerned why not disconnect the batteries and use a "Battery Tender" to maintain the batteries. IMO it's a better choice than the onboard converter since a Battery Tender is specifically designed to maintain batteries and not other functions.
2014 was around the time FR swapped to a Power Dynamics Converter which allows the switch to be off and still charge the batteries on shore power. Check and see if you have a Power Dynamics Converter, if you do you can leave the switch off.
08-06-2015, 09:46 AM
Wow, by your description the battery disconnect is a useless item. When the battery is disconnected I believe that what is still directly connected to the battery, except maybe for the O2 sensor, are items that route through switches and therefore are essentially open circuits unless that item switch is actuated.
08-06-2015, 10:55 AM
Well I'm going to assume for now I have a newer converter cause it was changed last month
I use the RV monthly and disconnecting the Batteries to put on a trickle charger sounds like a good winter option but too much hassle for on season
I mean if I have to plug in a trickle charger then the RV has to be plugged in and the converter is designed to keep the batteries charged ,so isnt this a little overkill?
What do other people do?
Im not going to run an extension cord out the window to plug in the trickle charger.
I guess the real question is why is it a problem to just plug into 110 and let the converter keep my batteries up.
What am I missing here?
'78.....tents
08-06-2015, 01:32 PM
It's easy to check and see if your batteries are being charged with the switch on or off. Plug in shore power, put a volt meter on your batteries and check the voltage with the switch on and off. Should read over 13 volts. If less in the off position, then you are not charging your batteries.
1968 tent trailer
1985 Jamboree 23 ft
08-07-2015, 09:35 AM
The installed converter should have a battery maintainer or float mode so it should be fine for summer between trips. Unless you are using a battery maintainer like "Battery Tender" which has float, trickle charge, and desulfication modes a so called trickle charger may be worse for the battery than the installed converter. You do not have to disconnect the batteries to use a Battery Tender. I only mentioned it because the poster seemed concerned having any load whatsoever on the batteries while in storage.
I store my RV in a garage so it's easier for me to use two battery tenders, one for the coach batteries and one for the chassis battery anytime I'm not using the RV. I have not researched the circuitry to determine if the chassis battery is also maintained when the installed converter is used during storage.
08-07-2015, 11:01 AM
Typically, on recently built units both coach and chassis batteries are charged when plugged into shore power. Also, both batteries are charged when driving. I believe the coach battery has priority with shore power and chassis battery has priority when driving. The coach battery has to be connected (not in storage mode) to be charged either way.
08-07-2015, 11:16 AM
Tinkerer and Putterer
Mine is a 2013 3011DS.
When storing for more than a few weeks I disconnect my coach batteries but I also pop all of my breakers. If I don't then the devices in the coach draw down the chassis battery.
I never charge without the battery switch on. I made the assumption that the switch needed to be on unless the charging circuit is connected directly to the battery and I didn't see a connection that lead me to believe that this was the case. It may be. The only way for you to know is to try it
When my coach batteries do get low I grab some tape or a bungee to hold the connect switch on and I use the chassis battery to start my genset.
Oh, and I always carry a set of jumper cables in case I REALLY mess up.
08-08-2015, 09:15 AM
Parked for a while
Just to be factual for those who might read this in the future, opening breakers (120 VAC) does nothing to affect the 12 VDC batteries, unless you are running an inverter which is a whole different discussion.
Honda CRV (TOAD)
08-09-2015, 05:10 AM
Turning off the battery disconnect will prevent any devices (parasites) from discharging the coach battery. That is the primary purpose of the disconnect switch.
If coach batteries are too low to start the generator, then start the engine. It will provide power to the coach batteries via the engine alternator. Otherwise, using the interconnect switch, if the generator doesn't start right away, you may end up with dead coach and chassis batteries.
2012 Forest River Sunseeker 2300 Chevy
08-10-2015, 08:15 PM
Retired
Our generator will not start unless we have more than a quarter tank of gas. Just sayin?
08-11-2015, 08:14 AM
Parked for a while
I talked to my Indy about how to "store the unit" between trips.
They have a fleet of rentals so they keep them plugged in cause they are prepping and turning around weekly,but for my needs they said unplug it and turn the Bat switch off.
Good point on fuel level.a lot of folks might have missed that.
I always keep at least half tank between trips at the storage farm,just in case of an emergency need for the RV it would be disheartening to need the unit and it's ability to generate it's own power just to find out you put it up with a quarter tank of gas and at the least,I like to use the RV for getting out of the heat or cold when we are there for the day playing with the horses (don't have 30amp service)
'78.....tents
