Don't mix a worn and a good tire on the same side of your duals. They will have different rolling circumferences and this will put more stress on the larger tire. If there's a significant difference in tread depth, try to match the tires on the same side. Of course, if you're replacing them based on age instead of tread wear, there may not be enough difference to matter.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
